Broken Antenna on car
Guest shinryuhoshi
Guest shinryuhoshi
My 93 Supra had its antenna broken off so all that's left is a small hole where the antenna used to be. When it rains or when I wash my car, water would go into the hole. Should I seal it up or is it fine the way it is?
  • 3 years later...
the rear inner arch has drainage? does it requires any rubber plug to be removed in order to drain the water or it will flow out naturally?
The electric aerial mast has a drainage tube the runs into a drain hole. When I replaced my electric with a stubby the hole in the rear arch was left open and i used silicon sealant to seal the rubber brommet to the body. I had no leakage issues.
