Lucifer Posted July 11, 2006 Share Posted July 11, 2006 I started rebuilding my Supra last year, but what with MKivStore poping up its taken a while. Here are some pics of the Engine in the final stages. Also I must stress this is MY own Engine in MY home Garage. This is NOT where customers engines get built, fitted or prepared. However saying that it was build by us of course! Spec Block New Toyota Block JE Pistons JE Pro Seal rings Carillo H-Beam Rods ARP Mains ARP Rod bolts ARP Head bolts 1.4mm Toyota Head gasket Block painted MKivStore Blue New starter Painted and polished PHR Street Alternator TRD Engine mounts - Polished + Painted Engine mount Brackets polished Dipstip polished Support bar polished Polished Stock intake and Throttle body (for run in period only then JUN) Turbo PHR Stage 1 Obiwan Tubo Kit MKivstore Custom compressort housing (not shown) HKS Genuine Manifold HKS 60mm Wastegate (not shown) Recireculating Dump into exhaust. Fuel system MKivStore Custom fuel system 850cc Injectors MKivStore Fuel rail - Twin feed MKivstore Fuel pump setup with dual Bosch 04 Pumps, Walbro Primer pump, Peltier Chilled Ally swirl pot. Aeroquip lines throughout Head New toyota Head Stock Guides Ferrea Valves 5 angle cut Not polished Slightly ported on exhaust side HKS 256, 264 Cams Titan Cam gears Im sure there is more.... I'll have a think. A duplicate is for sale @ £9400 Quote Link to comment Share on other sites More sharing options...
uk-rich Posted July 11, 2006 Share Posted July 11, 2006 cool, which phr turbo is that (size) Quote Link to comment Share on other sites More sharing options...
Gamer Posted July 11, 2006 Share Posted July 11, 2006 Looking good mate. Where did you get the belt tensioner from ? Quote Link to comment Share on other sites More sharing options...
Lucifer Posted July 11, 2006 Author Share Posted July 11, 2006 cool, which phr turbo is that (size) It is the Obiwan Street kit DBB Looking good mate. Where did you get the belt tensioner from ? Us we supply and make these. When I launch this engine / car fully we will be launching a whole range of engine bling parts too. Ill keep you posted Joe as I noticed we are doing most of the things you dont currently have on your engine. Quote Link to comment Share on other sites More sharing options...
Gamer Posted July 11, 2006 Share Posted July 11, 2006 Sounds good, keep in mind that I am not one to wait about too long... Quote Link to comment Share on other sites More sharing options...
Lucifer Posted July 11, 2006 Author Share Posted July 11, 2006 Maybe I can sort soem out pre production for you eh? I'll get some photos up asap. Quote Link to comment Share on other sites More sharing options...
Gamer Posted July 11, 2006 Share Posted July 11, 2006 Cash waiting Quote Link to comment Share on other sites More sharing options...
Lucifer Posted July 11, 2006 Author Share Posted July 11, 2006 Oh Mannn you know how to tempt! LOL Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted July 11, 2006 Share Posted July 11, 2006 Looking good. Which car is this going into, track, drag, street or drift!! Gaz. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted July 11, 2006 Author Share Posted July 11, 2006 Drif and TRack car are now one of the same. This is for my street / show car. Quote Link to comment Share on other sites More sharing options...
tbourner Posted July 11, 2006 Share Posted July 11, 2006 Sweet. Quote Link to comment Share on other sites More sharing options...
Guest dee_rz Posted July 11, 2006 Share Posted July 11, 2006 yum Quote Link to comment Share on other sites More sharing options...
Kranz Posted July 11, 2006 Share Posted July 11, 2006 I'm liking that martin!! If I come back to Thornbury sometime any chance of a quick peek??? Steve Quote Link to comment Share on other sites More sharing options...
Lucifer Posted July 11, 2006 Author Share Posted July 11, 2006 Yeah sure, it may even be in the car by then. Quote Link to comment Share on other sites More sharing options...
TLicense Posted July 11, 2006 Share Posted July 11, 2006 Very nice mate! I'm liking the coloured block a lot. Wonder if you could quickly tell me though, the water hose that goes around the back of the block. Is it just held on by the two bolts one on either side of the block, or is there one that holds it on the back of the block? I want to remove it so I can loose the two air lines that go to the pressure tank that I no longer have, and I want to remove the spare water exit, that I'll no longer need. Cheers, Tony Quote Link to comment Share on other sites More sharing options...
j80leo Posted July 11, 2006 Share Posted July 11, 2006 thats looking the bollocks;) Quote Link to comment Share on other sites More sharing options...
Lucifer Posted July 11, 2006 Author Share Posted July 11, 2006 Just the 2 on the side Tony. Thanks all for the comments Quote Link to comment Share on other sites More sharing options...
TLicense Posted July 11, 2006 Share Posted July 11, 2006 Awesome, cheers mate. Quote Link to comment Share on other sites More sharing options...
stupra Posted July 11, 2006 Share Posted July 11, 2006 Looks good mate. Once my outside is sorted, i'll be after some engine bling. Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 11, 2006 Share Posted July 11, 2006 Nice blue What sort of prep, primer, and paint did you use....? Can it be applied to the cylinder head as well...? Quote Link to comment Share on other sites More sharing options...
Lucifer Posted July 11, 2006 Author Share Posted July 11, 2006 Nice blue What sort of prep, primer, and paint did you use....? Can it be applied to the cylinder head as well...? Prep ---- An Aweful lot of hand work went into this to take off any course casting. Dremmel, DA, file. you name it itwas done. Primer ------ None Direct HTA Paint Paint ----- We used a Custom HTA paint mix, mixed for us by the car paint wharehouse. LOL I have never even considered the head. I would say no, mainly for the fact you need contrast! Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 11, 2006 Share Posted July 11, 2006 HTA? That's something to do with heat, right? What would I ask for at a shop? So clean up and degrease the block, and then paint it with this stuff. Mmmm. I was thinking cylinder head "instead of" rather than "in addition to", seeing as it's easier to reach. You'd have to be mad to pull the engine just to paint it -Ian Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 11, 2006 Share Posted July 11, 2006 looking good:cool: can we have a spec? Quote Link to comment Share on other sites More sharing options...
Gazboy Posted July 11, 2006 Share Posted July 11, 2006 Looks awesome! Quote Link to comment Share on other sites More sharing options...
b_have Posted July 11, 2006 Share Posted July 11, 2006 It is the Obiwan Street kit DBB Is this the stage2 PHR we were talking about? Looking forward to your feedback on this. (btw looking sweet!) Quote Link to comment Share on other sites More sharing options...
