Lubas Posted July 9, 2006 Share Posted July 9, 2006 hey guys and gals, i'm doing the cambelt need to get the crank pulley off. when i try to undo the crank pulley bolt the pulley just spins. i've tried putting it in gear but the car just moves!! does anyone know how to lock the pulley so i can undo it? any help would be greatly appreciated!! thanks,Ben:thumbs: Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 9, 2006 Share Posted July 9, 2006 mate ideally you need a tool like the one in this attached picture....it screws into the two holes on the pulley and then rests on the inner drivers side wing to lock the pulley. Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 9, 2006 Share Posted July 9, 2006 take it your car is a manual? if so then i think your in gear method can work if you get a volunteer to sit holding the brakes on Quote Link to comment Share on other sites More sharing options...
Lubas Posted July 9, 2006 Author Share Posted July 9, 2006 ok mate!! your a star!! i'll try that now Quote Link to comment Share on other sites More sharing options...
normore1 Posted July 9, 2006 Share Posted July 9, 2006 Either use the tool described above or place a breaker bar on the nut and brace it against the chassis then engage the starter a couple of times (make sure you have a fully charged battery). You may need a cheater pipe on the breaker bar to ensure it braces against the chassis and won't hit any essential component (watch out for the A/C pipes). If this does not free the nut then you will need the tool. You will also need the cheater pipe and lots of muscle. Quote Link to comment Share on other sites More sharing options...
Lubas Posted July 9, 2006 Author Share Posted July 9, 2006 as i turn the bolt the pulley moves just enough for me not to be able to turn the bolt anymore because my wrench hits the wing. think i'm gona have to get one of the special tools. do you know where i can get one like the one in the picture? Quote Link to comment Share on other sites More sharing options...
Bob Posted July 9, 2006 Share Posted July 9, 2006 mkivstore sell the crank bolt / pulley removal tool, iirc. Quote Link to comment Share on other sites More sharing options...
Lubas Posted July 9, 2006 Author Share Posted July 9, 2006 great. thanks mate, i'll get on tomorrow Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 9, 2006 Share Posted July 9, 2006 Lubas, where exactly in Kent are you? Quote Link to comment Share on other sites More sharing options...
LeeT Posted July 9, 2006 Share Posted July 9, 2006 also marksupra on here has one which he lends out to fellow members Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted July 9, 2006 Share Posted July 9, 2006 it might be worth trying an air gun on it first, the fact that they judder might be enough to crack the threadlock stuff just a thought Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted July 10, 2006 Share Posted July 10, 2006 As a heads up, mine failed to come off with any of the above methods, I ended up buying a new bolt and large chisel, took ages to get it to shift... Quote Link to comment Share on other sites More sharing options...
garethr Posted July 10, 2006 Share Posted July 10, 2006 ......place a breaker bar on the nut and brace it against the chassis then engage the starter a couple of times............ with the plugs out or disconnected so that it doesn't start up Quote Link to comment Share on other sites More sharing options...
normore1 Posted July 10, 2006 Share Posted July 10, 2006 ...... with the plugs out or disconnected so that it doesn't start up yep!!! Forgot that part, but thought it might be obvious. Quote Link to comment Share on other sites More sharing options...
Guest Draven Posted July 11, 2006 Share Posted July 11, 2006 I've just been through this with my car. The method that worked for me was: 1. inox/wd40/lubricant (I used inox due to previous excellent experience) 2. tap it with a hammer. the shock will help to loosen any rust that may be holding it on. 3. (heat). I didn't use this, but it was next on the list. 4. breaker bar + BIG extension bar braced against the ground, and crank it over with the starter motor. Quote Link to comment Share on other sites More sharing options...
geoffvalenti Posted July 11, 2006 Share Posted July 11, 2006 3. (heat). I didn't use this, but it was next on the list. FFS don't use heat EVER. You'll damage the rubber section of the pulley Quote Link to comment Share on other sites More sharing options...
