Topped up with oil...now got clutch slip!?
Sean1933
Well i got my car last weekend and i love it, but i have had quite a few problems with it since ive then!
I was sitting on a slant the otherday and the oil low warning light came on (yellow one). So i got home and checked it, sure enough the oil level was pretty much on the bottom of the dip stick! I am planning on doing an oil change as soon as i get my filter from MKivstore.com and have the time. So i topped it up with a ltr of Mobile1 fully synthetic 0w-40.
Anyway, this was last night when i topped it up. On the way to work this morning i notice that the clutch is slipping in 3rd, 4th,5th,6th. Maybe even in 2nd! Does anyone have any ideas why its started slipping now, or is it just coinsidence that i topped it up with a thin oil? :search:
I really hope i dont have to get a new clutch and flywheel cause thats money i dont have right now...Please help! :(
Its coincidence mate, you shouldnt top up with different thickness oil, id get a change done soon and would use 5w40 as a minimum as 0w has been known to get past the rings.
YOu dont have to change your flywheel mate, i didnt, just the clutch and thrust bearing if thats the extent of the wear.
If my seal has gone then how hard of a job is it? What would it cost for parts?
Also would i need a new clutch/flywheel?
I wouldn't say you'd definitely need a new clutch but it may be sensible to do if its worn as the extra labour won't be much.
The seal i'd imagine is £10 or so, and i doubt the job is any more difficult than a clutch change in general.
Can you get the car onto axle stands and whip off the clutch inspection cover? (It's only two 10 or 12mm bolts) and see if there's leaked oil in there?
i should be able to. My only question is will i need to remove the clutch to get at the rear seal? If so then will i need to replace the thrust bearing? How much are they?
Yeah, it's gearbox off, clutch off, flywheel off to change the rear crank seal.
I don't think the release bearing would have suffered but I'd change it anyway, they can't cost much. If there's oil on the clutch plate it's knackered. You'll need new flywheel bolts as well (about £80 I think)
It might not be the rear crank seal anyway, we're just guessing at the moment.
I have a feeling it might be the oil seal because when i got the car from a reputable trader i was told the levels were checked and topped up...but it cant have gone down to the min level in a week/600miles without something being amiss?
Can you take it back to the trader and let them sort it out?
I will check it when i finish work at 5.00.
I think i mixed my words abit. Not so much a trader but importer...got it from Jurgen and he is 400 miles away! (and i dont hold him to fault, just my bad luck with cars!)
Can what be done? You can change a clutch on axle stands but it'll be hard graft. I wouldn't want to do it. Taking the clutch inspection plate off is a quick and easy job.
Yes oil on the clutch plates would require replacement, as I said before in post #10. The flywheel might be ok if it hasn't been slipping too long, you'll have to have a look at it when it's stripped down.
Yes thats what i ment, change the clutch on axle stands...its the only way i can do it really without getting someone else to do it...and thats more money! Do you know if you can buy just the plates for the standard clutch?
Also would i need any special tools atall to change the clutch?
Sorry for all the questions, just weighing up my options.
Valve stem seals and turbo oil seals usually though, no?
i've had two instances of yellow/low level oil warning light........neither were the above.
One was the oil pressure sensor switch and one front crank seal gone.
I'm pretty sure turbo seals and Valve stem seals will show other more obvious and gradual symptoms before the low level warning light........
Well thats good to know scooter!
So what are peoples views on changing the clunch on the ground, being on axle stands? I havent done it before but car read instuctions and im good with my hands :)
Or would you need a pit/ramp...in which case someone else having to do it! :(
