Guest JS_TT Posted July 10, 2006 Share Posted July 10, 2006 Porsche looks nice. Should be quite an animal. I have not really done much with the cd player other than load in 6 discs and play-lol. Might look into settting it up properly at some point when I find a spare moment. Carl If you do need a hand with it, just give me a shout. Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted May 8, 2009 Share Posted May 8, 2009 Got the same problem today :/ I floor it and it doesnt change into 4th. So is it just if kickdown is still pressed? Quote Link to comment Share on other sites More sharing options...
AndyT Posted May 8, 2009 Share Posted May 8, 2009 Ian C explanation Have a read. The box is virtually faultless. Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted May 8, 2009 Share Posted May 8, 2009 I know this Manu was off and overdrive on. I went out to test it again. Floored it and: Changed nicely into 4th??!? So now it works. I didnt do anything Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted May 8, 2009 Share Posted May 8, 2009 (edited) Uhm just to clearify this. It runs to about 6700-6800 and then the motor breaks, rev drops to about 6300-6400 after that the car accelerates again to 6700-6800 -> rev drops again and so on. Is that rev limiter or mayb speed limiter? On rev limiter it should break power to a neutral level and hit rev limiter all the time. Dont know how speed limiter works. But i dont expect it to break speed and then accelerate again. add: http://www.mkivsupra.net/vbb/showthread.php?t=10193&highlight=3rd+4th Looks similar to this one. Sadly my speedo doesnt work correctly so i dont know how fast i was going. add: http://www.mkivsupra.net/vbb/showthread.php?t=183378&highlight=speed+limiter sound also like this. Edited May 9, 2009 by Carsten (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Carsten Posted June 1, 2009 Share Posted June 1, 2009 Any ideas? Quote Link to comment Share on other sites More sharing options...
