Auto gear change up problem from 3rd to 4th
Carl
Guest JS_TT
Porsche looks nice. Should be quite an animal.
I have not really done much with the cd player other than load in 6 discs and play-lol. Might look into settting it up properly at some point when I find a spare moment.
Carl
If you do need a hand with it, just give me a shout.
  • 2 years later...
Guest Carsten
Got the same problem today :/
I floor it and it doesnt change into 4th.
So is it just if kickdown is still pressed?
Guest Carsten
I know this ;) Manu was off and overdrive on.
I went out to test it again. Floored it and: Changed nicely into 4th??!?
So now it works. I didnt do anything
Guest Carsten
Uhm just to clearify this.
It runs to about 6700-6800 and then the motor breaks, rev drops to about 6300-6400 after that the car accelerates again to 6700-6800 -> rev drops again and so on.
Is that rev limiter or mayb speed limiter?
On rev limiter it should break power to a neutral level and hit rev limiter all the time. Dont know how speed limiter works. But i dont expect it to break speed and then accelerate again.
add: http://www.mkivsupra.net/vbb/showthread.php?t=10193&highlight=3rd+4th Looks similar to this one. Sadly my speedo doesnt work correctly so i dont know how fast i was going.
add: http://www.mkivsupra.net/vbb/showthread.php?t=183378&highlight=speed+limiter sound also like this.
Edited by Carsten (see edit history)
  • 4 weeks later...
