Ticking noise from brake discs (3G)
supraman.chris
The facing of the discs should bedependent on the angle of the venting inside them, in that its hould beexpelling air rather than tring to scoop it in.
Are you sure? Mine (stock UK) were like that, i.e. the internal slots were going \\\ on the way round, so not taking any air in. This seemed wrong, as definately was wrong when I looked since the discs were marked 'RH' and 'LH' and were on the wrong side. I had warping problems when braking at speed. I switched them around so that they scoop air in ( /// on the way round) and so they matched up with the RH/LH markings, and all is well.
