coolant temps at weekend
baldy
hi chaps
did any one else suffer with their car getting hot at the weekend?
im bpu,hks r type fmic,fluidine rad
but the temps still climbed when in boost,i was startin to think head gasket again(nnoooo)
but just been out for a blast and it seems fine now
i thought the fluidine rad would have coped ok
anyone else suffer atall
cheers baldy
I didn`t have any problems at the weekend, but have always experienced temp gauge climbing to mid way round very quickly (five minutes from cold) and cooling down time really long. Checked coolant level several times and all is well. Is this normal or do we have a problem Houston??
Guest mk47
i had the problem over the weekend too, but its fine i think its just because of the hot weather.
Hi Si
Do you mean the stock water temp gauge was higher than normal? That's unusual, mine never goes above normal unless the rad is about to boil over.
I have an oil temp gauge with the sender in the sump, and I've noticed it getting a little hotter than usual during the recent heatwave but nothing to be concerned about. I do have an external oil cooler though.
hi jake
Hi Si
yes jake thats what i mean and why i was worried,only while in boost tho
but it was fine last night,i think maybe im being a bit paranoid about things
