baldy Posted July 4, 2006 Share Posted July 4, 2006 hi chaps did any one else suffer with their car getting hot at the weekend? im bpu,hks r type fmic,fluidine rad but the temps still climbed when in boost,i was startin to think head gasket again(nnoooo) but just been out for a blast and it seems fine now i thought the fluidine rad would have coped ok anyone else suffer atall cheers baldy Link to comment Share on other sites More sharing options...
suprasurrey Posted July 4, 2006 Share Posted July 4, 2006 I didn`t have any problems at the weekend, but have always experienced temp gauge climbing to mid way round very quickly (five minutes from cold) and cooling down time really long. Checked coolant level several times and all is well. Is this normal or do we have a problem Houston?? Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 5, 2006 Share Posted July 5, 2006 I didn`t have any problems at the weekend, but have always experienced temp gauge climbing to mid way round very quickly (five minutes from cold) and cooling down time really long. Checked coolant level several times and all is well. Is this normal or do we have a problem Houston?? i had the problem over the weekend too, but its fine i think its just because of the hot weather. Link to comment Share on other sites More sharing options...
Jake Posted July 5, 2006 Share Posted July 5, 2006 Hi Si Do you mean the stock water temp gauge was higher than normal? That's unusual, mine never goes above normal unless the rad is about to boil over. I have an oil temp gauge with the sender in the sump, and I've noticed it getting a little hotter than usual during the recent heatwave but nothing to be concerned about. I do have an external oil cooler though. Link to comment Share on other sites More sharing options...
baldy Posted July 5, 2006 Author Share Posted July 5, 2006 hi jake Hi Si Do you mean the stock water temp gauge was higher than normal? That's unusual, mine never goes above normal unless the rad is about to boil over. . yes jake thats what i mean and why i was worried,only while in boost tho but it was fine last night,i think maybe im being a bit paranoid about things Link to comment Share on other sites More sharing options...
RedM Posted July 5, 2006 Share Posted July 5, 2006 I noticed that with just the ignition on (but engine not) the water temp in mine rose higher than halfway but actually starting the engine dropped it back down to half again. Normal? Link to comment Share on other sites More sharing options...
