Offsets yet again guys sorry
psymon
its not really just offset related, its also down to wheel and spoke design too. YOU can have a 46mm offset which would fit fit but a different make/style of wheel in the same offset will not. Its alot of trial and error im afraid
Hi Si
In simple terms the smaller the offset number the further out the wheels will fit. So as an example, if you had exactly the same model of wheels then the +30 offset will give you more brake clearance compared to the +35.
What are the widths and model of the wheels? As the width and design of the wheels will also determine whether they will clear the larger brakes.
This is a useful link for comparing offsets.
http://www.1010tires.com/WheelOffsetCalculator.asp
Also read THIS and THIS and then decide if you want to use spacers or not on a 180mph Supra car ;)
