psymon Posted July 4, 2006 Share Posted July 4, 2006 Will 18 wheels clear uk brakes with only a +30 offset front Rears are +45 so no probs there...... Coulds I use spacers on front Current wheels are +35 front and these clear no probs thankyou Si Link to comment Share on other sites More sharing options...
toyotatom Posted July 4, 2006 Share Posted July 4, 2006 Have a look in the technical section under thread called offsets started by me. Might be some useful replies to my question there. At least its something to do while you wait for people to reply to this one. Link to comment Share on other sites More sharing options...
LeeT Posted July 4, 2006 Share Posted July 4, 2006 its not really just offset related, its also down to wheel and spoke design too. YOU can have a 46mm offset which would fit fit but a different make/style of wheel in the same offset will not. Its alot of trial and error im afraid Link to comment Share on other sites More sharing options...
merckx Posted July 4, 2006 Share Posted July 4, 2006 This may be helpful, it's supposed to be a cross section of the front hub with UK brakes. It might be best to verify this first by taking a few measurements. Link to comment Share on other sites More sharing options...
wkdtime Posted July 4, 2006 Share Posted July 4, 2006 Lee's partly right, but if theyre +30 for the fronts then im 99% sure it'll be fine mate. The more negative the offset the more the wheel will sit away from the caliper rotation. Link to comment Share on other sites More sharing options...
toyotatom Posted July 4, 2006 Share Posted July 4, 2006 Does this meen they will sit outside of the normal arches? Link to comment Share on other sites More sharing options...
LeeT Posted July 4, 2006 Share Posted July 4, 2006 Does this meen they will sit outside of the normal arches? good point, that offset will stick out 20mm more than stock wheels Link to comment Share on other sites More sharing options...
Nic Posted July 4, 2006 Share Posted July 4, 2006 Hi Si In simple terms the smaller the offset number the further out the wheels will fit. So as an example, if you had exactly the same model of wheels then the +30 offset will give you more brake clearance compared to the +35. What are the widths and model of the wheels? As the width and design of the wheels will also determine whether they will clear the larger brakes. This is a useful link for comparing offsets. http://www.1010tires.com/WheelOffsetCalculator.asp Also read THIS and THIS and then decide if you want to use spacers or not on a 180mph Supra car Link to comment Share on other sites More sharing options...
toyotatom Posted July 5, 2006 Share Posted July 5, 2006 Thank the Lord for overfenders Link to comment Share on other sites More sharing options...
wkdtime Posted July 5, 2006 Share Posted July 5, 2006 Yeah that...isnt that what i said huh NIc Link to comment Share on other sites More sharing options...
