Gazboy Posted July 3, 2006 Share Posted July 3, 2006 The previous owner of my car, in her infinite wisdom chose to drill loads of holes in the airbox. It's been on my "to-do" list for ages btw. Yesterday at Brunters I found the car was reluctant to accelerate in top gear (I say reluctant, I still ran down a Z3M like it hit a vat of treacle) and initialy thought it might just have been because of the tall top gear. Then I started thinking a bit more. Could the heat build up from the engine bay reduce my power at sustained WOT due to the cold air feed being breeched by the drill-holes? My intercooler, while not brand new isn't in bad nick btw. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted July 3, 2006 Share Posted July 3, 2006 . It's been on my "to-do" list for ages btw. Thats a joke right Could the heat build up from the engine bay reduce my power at sustained WOT due to the cold air feed being breeched by the drill-holes?. Heat will cause the ECU to bring back the ingnition causing a sluggish feeling, I doubt its the box though TBH.....how big are the holes?? Quote Link to comment Share on other sites More sharing options...
Gazboy Posted July 3, 2006 Author Share Posted July 3, 2006 4-5mm, and there are loads of them. Not a joke- there has always been something else needing money instead... (like that scum who rammed my car with a trolley, now I need a new wing) Quote Link to comment Share on other sites More sharing options...
Marco Posted July 3, 2006 Share Posted July 3, 2006 Sounds terrible! Any pictures? Quote Link to comment Share on other sites More sharing options...
Homer Posted July 3, 2006 Share Posted July 3, 2006 Why not just gaffer tape them up and see if the problem persists? Quote Link to comment Share on other sites More sharing options...
Gazboy Posted July 3, 2006 Author Share Posted July 3, 2006 Why not just gaffer tape them up and see if the problem persists? I might do next time. A friends 993TT had to have it's splitter tapped up this time, but I didn't put two plus two together at the time. Quote Link to comment Share on other sites More sharing options...
JohnA Posted July 4, 2006 Share Posted July 4, 2006 Why not just gaffer tape them up and see if the problem persists? yeah, use DuckTape and if it feels better then look for an old and unloved airbox. Lots about with people shelling out for 'performance' cone filters. Quote Link to comment Share on other sites More sharing options...
Gazboy Posted July 7, 2006 Author Share Posted July 7, 2006 yeah, use DuckTape and if it feels better then look for an old and unloved airbox. Lots about with people shelling out for 'performance' cone filters. I'll give it a go next time I'm working sat night (sun morning, motorway...) I'm not entirely convinced this will be the magical fix, I think there is something expensive in distress. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 7, 2006 Share Posted July 7, 2006 The amount of airflow through the engine bay at that speed, its unlikely to be the airbox IMO Quote Link to comment Share on other sites More sharing options...
Pete Posted July 7, 2006 Share Posted July 7, 2006 I remember when this was all the rage about 10 years ago with small euro hatch owners. Not something I've ever advocated I might ad. Horrific to think it done to a Supra Quote Link to comment Share on other sites More sharing options...
Todd Posted July 7, 2006 Share Posted July 7, 2006 I remember when this was all the rage about 10 years ago with small euro hatch owners. Not something I've ever advocated I might ad. Horrific to think it done to a Supra Guilty as charged, think I've still got the copy of max power up in the loft that explained the benefits and showed you how to do it Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 7, 2006 Share Posted July 7, 2006 They do it on Soarers, except we cut the front of the airbox out and seal it from the engine bay. Its called a BFI (Big Fookin Intake) Plenty of dyno results to back it up. And while Im on accronyms, whats a BPU?! Quote Link to comment Share on other sites More sharing options...
Guest rabskyline Posted July 8, 2006 Share Posted July 8, 2006 is the engine bay so tight that the airbox being drilled would be a problem?? at most it should help the engine breath "!!!! i cant see why this would make it sluggish. do you have an oil cooler fitted ? is your intercooler wing mounted ?? it has been warmer lately but shouldnt make any difference coz japan is miles hotter and humid like you wouldnt believe ! i might be off track here but i dont think an airbox would strangle it ! Quote Link to comment Share on other sites More sharing options...
carl0s Posted July 8, 2006 Share Posted July 8, 2006 And while Im on accronyms, whats a BPU?! Basic Performance Upgrade. A "BPU'd" (or just BPU) Supra-turbo is one which has had the essential basic mods done to allow better spool-up and higher boost. That'd be Exhaust/De-cat, FCD and a boost-control thing (and anything else that might be required along the way (say perhaps bigger injectors on a Jap car)). Quote Link to comment Share on other sites More sharing options...
Gazboy Posted July 10, 2006 Author Share Posted July 10, 2006 is the engine bay so tight that the airbox being drilled would be a problem?? at most it should help the engine breath "!!!! i cant see why this would make it sluggish. do you have an oil cooler fitted ? is your intercooler wing mounted ?? it has been warmer lately but shouldnt make any difference coz japan is miles hotter and humid like you wouldnt believe ! i might be off track here but i dont think an airbox would strangle it ! Stock smic (which appears to be ok, but not in A1 condition), no aftermarket oil coolers. Quote Link to comment Share on other sites More sharing options...
gordy.r Posted May 20, 2014 Share Posted May 20, 2014 Sorry to resurrect a post from the Dark Ages, but it was something I was searching for (like a good boy before I get told off for posting a new thread ) and I only found one thread that matches my search! (this one). I remember this being something we did on VAG engines a while back for improved aural pleasure but it 'supposedly' added performance gains as well... if you believe the Max Power hype lol Nice to see it has been discussed and pretty much found to offer no benefits unless you do some serious modding like the Soarer boys. Quote Link to comment Share on other sites More sharing options...
gordy.r Posted May 20, 2014 Share Posted May 20, 2014 P.S. I would have hoped the airbox being discussed here had been drilled pre filter and not after the filter as this would be pretty pointless and bad for the engine! Quote Link to comment Share on other sites More sharing options...
