shuttering at take off
cntt
sometimes I get this shuttering at take off, only happens after having driving the car for a while, when its cool start and let engine worm up to normal temp, then take off, it doesn't happens, only after driving for a good few miles, then stop at traffic or lights, and take off again, I can feel this shuttering, if I play with the clutch to some possition I can take off smoothly
any idea what that might be? I couldn't figure out why it only does it after driving for a while every time after it cools down before that will happens, it has a new clutch fitted not very long ago.
cheers
not sure which clutch, it was put in just before I got it, it doesn't say on the reciept, I was told it is a uprated clutch, its afeels a little stiffer than a normal clutcl but not as stiff as the stage 2 I had in the ITR before. speaking of that I remember now when I first got the ITR it was a uprated clutch installed when I first got it and it was the same till I put in the stage 2, except in the ITR it does it all the time no matter how I play with the cluch and throttle, warm or cold, the only same thing between them was that if I take off quick with let out the clutch quicker, its fine.
smooth changing gear
rev doesn't jump and engine doesn't hesitate at all.
