Running Lean
Steve
  • Replies 145
Posted Images
Alex,
Havent got the old injectors anymore. Have tried a different Emanage unit and a stock ECU.
Can i just unplug the RLTC box just to prove that this isnt doing something weird?
You can disconnect the RLTC from the loom but obviously you need to join the wires back together!!
I'd see if you can borrow some 440cc injectors and test with them in.
did't read all your posts so it might have been covered but i had a similar problem with my afr's reading low at times, and i managed to trace it to a bad connection on the fuel pump connector block in the boot might be worth checking. normally with bad connections the wires tend to slightly discolour and are brittle due to heat build up which you can look for, also leave engine running when checking wiring and connecters to see if you hear a change in engine sound.
The car is now throwing up a fault code of 31.
According to the manual it is something to do with the Air Flow sensor circuit. But mine is a Jap car and doesnt have a Air Flow meter.
So what can cause this fault?
steve did change the intake air temp sensor when you done the various sensors??
Homer - thanks for watching the vid mate and providing your comments. Much appreciated. I wasn't sure if my AFRs should be swinging like that at low revs i.e. below 4,000rpm. That's kind of good news I suppose although I don't know if the problem persists above the 4k mark when the 2nd Tubbie comes in!
All I know is it's damn scary watching the gauge creep into the red 16's when pulling off or poodling around!
So, is this completely normal then for my stock J-spec setup ???(with new hybrids and BPU parts but still running Sequential)
Thanks ;)
Smarty - I really hope you sort this buddy. Fingers crossed for you. As I said, if Chris Wilson flags anything up abnormal in mine I'll give you a shout buddy! :) Good luck.
Greg
AFM code = MAP code on a J-spec. (I believe). I'd swap the sensor and re test.
A fault code 35 is the turbo presure sensor. I swear we've been through this before :blink:
Anyway, easy to test:
1. clear the ECU of error codes
2. unplug your MAP sensor at the sensor itself (not the hose, the wiring plug)
3. fire up the engine and your check engine light should come on (and it'll run like a bag of spanners)
4. Switch off and check your codes again. You'll either get a 31, a 35, or both :) Let us know!
-Ian
Not much help now i know, but i did mention a while ago about checking the ECU water temp sensor and the air temp sensor ( I'll have a look in the manual for testing) and i think it was also mentioned about checking the MAP sensor, it always pays to check the small easy to get at bits first;) good luck!
You have checked the lambda sensor i take it?
Have changed the water temp sensor, just need to test the Air temp sensor ( just need the resistance value it should be at ).
Ian C has looked at Datalogs from the car and MAP sensor was close to the Greddy Pressure sensor, so dont think it could that.
  • 5 months later...
After looking at every possible fault, i gave up and took the car down to Matt Harwood.
Matt had the car for a few weeks trying to find the problem, then thanks to another chat with Ian C, they found that the poxy Wideband sensor was at fault.
This was the one thing that i didnt think to check as it was less than a year old.
But now its all working fine and after some mapping work by Ian the flies again.
Ah well you live and learn :)
