Running Lean
Steve
  • Replies 145
Posted Images
Have got all this week off so, if the ECU dont work will try and get it down to you.
Is it best to ring first?
Whats the cost per hour? £1.50 ;)
Best to ring first, yes please.
As for the hourly rate, hmmm I think you misplaced the decimal point... By how many spaces though... :p
Have taken the advice from Matt and took all the intake side apart, to get to the seals form the head to inlet runners and inlet runners to the intake plenum.
The seal that goes between the runners and the head does look quite poor, all the plastic covering on the seal is flaking away. So could be causing an air leak. Will order some new gaskets tomorrow from Toyota.
Is there anything that i can do the runners and plenum whilst they are off the car?
The runners do have some crap inside so could do with a clean. What can they be cleaned with?
Thanks
  • 1 month later...
**Update**
Right have changed all the intake seals around the inlet runners, plenum, throttle body, IACV and the injector seals.
Fired it up today and its still the same :(
I tried another stock ECU and its still the same :(
The only thing i can now think of is where the car has been sitting it has blocked up the injectors, i do use Tescos fuel so dont know whether it dont like sitting for a while. So am gonna remove the injectors and get them tested and cleaned and see what happens.
Jesus Steve this has been going on a while pal. Good and bad news though - the 'Good' (lol) news is I'm having EXACTLY the same problem, the bad news, I'm having this problem! and I haven't tested anything or got it sorted yet as don't have the techy techy knowledge! :(
Mine can idle between 13-15 at anytime. Today I put my foot down and it raised to 15.5, took foot off accelerator and it dropped to 13 for a split second then back up to mid 14's. It never runs rich or below 13 for more than a few seconds. Bascially, I too am running lean with average between 14-15 all the time - it's damn scary.
Mine's a J-spec TT with Hybrids and standard injectors. No fuel management ECU or the like. I have an AEM UEGO Wideband AFR gauge which was plumbed in by Phoenix Performance in May 2006. I have no idea what's wrong.
The good news is thast I'm taking my car to Chris Wilson this saturday to get it tested so he'll hopefully 'cure' the problem and I'll let you know the results.
Good luck buddy. ;)
Greg
  • 2 weeks later...
Right have had the injectors cleaned, before cleaning they were ok and the spray pattern was fair, but now Good.
Refitted them and tested the car, it has stayed the same.
Also tried changing the Water Temp Sensor on Gregs advice (thanks for the loan sensor) and it seemed to start working ok. But after a few seconds it went back to running lean. Came back home and checked all the connections to everything, went out again and found it would intermittently go lean, not all the time like it had been.
Tried it again this morning and its just doing it randomly, one minute the AFR's are perfect, then the next minute it goes lean.
So something like a sensor could be doing this.
Any ideas??
Any ideas??
deffo sounds like an electrical gremlin,could be a bitch to find mate.You will get there in the end though ,chin up lad!
Just put the Water temp sensor in the freezer for a while and put the meter on it and it still has the same reading that it had while at room temperature.
According to the manual it should be between 4-7k at 0 degrees and at 2-3k at 20 degrees, it seems to be staying at 2-2.5k.
Just goimg on what Greg said that if this sensor was fooked it could make it run lean or rich depending which way the sensor was sticking at.
another problem that shows up with this sensor is that your car will struggle to start a lot of the time when you try to start it once the car has been taken for a long run and is warm.
Have you had this problem steve?
Steve and Rich. I have the EXACT same symptoms too.
My AFRs can be great one minute and then suddenly in an instant second switch from 13 to 16 and stay there for a while. If I turn the engine off and restart it'll stay at 14 then slowly rise to 15ish.
I also have a problem starting when the car is warm.
sheefa,swap your coolant temp sensor mate,same symptoms with my old car and it was that!
Thanks Rich. Car is with Chris Wilson at the moment so hopefully he'll do the testing and sort it - but I'll pass this message on! Where abouts can you get a new coolant temp sensor from mate? Thanks again ;)
BTW - Has anyone managed to view the vid of the random AFR readings? It's in phone 3gp format but can be converted. Link below :)
http://download.yousendit.com/F85CB45059374E53
Also - Rich, lovely white sup mate. Clean and beutiful looking!
your best bet is Mr T buddy
Your vid of the AFR gauge looks perfectly normal mate, it'll be swinging all over the shot while off boost/low boost. AFAIK the reasing is only really relevant on a stock TT when the 2nd tubbie is online. If poss get a vid of you cruisng at 3500rpm, then floor the throttle until near max RPM. No use doing in lower gear, must be high gear (3rd auto, 4th or 5th manual). If its anything like mine it will have a nasty lean spot between 4000rpm and 4500rpm then at 11.8 until redline (1.25bar)
Edit - btw above is aimed at Sheefa
