Paul R Posted January 31, 2004 Share Posted January 31, 2004 Hi, I'm waiting for the info for my alarm to come through in the post - as someone who shall remain nameless *Paul E* :D picked em up by accident when I picked up my car, no we are 200 miles appart!! Today I want to install my stereo and subs. But I need to disconnect the battery - Do I need the alarm pin code after I have done this? or is that only needed if you havent got a key fob? Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
LeeT Posted January 31, 2004 Share Posted January 31, 2004 im pretty sure the only time you need the pin code is when youve lost the fob. i had this alarm on my old car and i disconnected the battery loads of times and i never once used the code over ride. so i think you should be ok. .lee Quote Link to comment Share on other sites More sharing options...
Paul R Posted January 31, 2004 Author Share Posted January 31, 2004 Originally posted by leett im pretty sure the only time you need the pin code is when youve lost the fob. i had this alarm on my old car and i disconnected the battery loads of times and i never once used the code over ride. so i think you should be ok. .lee Thanks for that matey!! I just wanted to check before I take the terminal off the battery!! I'll get on with my install then!! I'll get some pics up later too!! :D Paul. Quote Link to comment Share on other sites More sharing options...
SimonB Posted January 31, 2004 Share Posted January 31, 2004 Just to confirm, you don't need the pin. I have this alarm and I've disconnected the battery loads of times. Quote Link to comment Share on other sites More sharing options...
