Angarak Posted June 30, 2006 Share Posted June 30, 2006 Is it normal to hear a rattle from underneath the car when you change gear? It seems to be more noticeable when shifting into lower gears. I believe my car came with an uprated clutch but Im not sure if it has the OEM or aftermarket flywheel - I think its OEM as it doesnt rattle on tickover. Any ideas gratefully appreciated. Simon Quote Link to comment Share on other sites More sharing options...
Lucifer Posted June 30, 2006 Share Posted June 30, 2006 Let me guess 6 Speed? Quote Link to comment Share on other sites More sharing options...
Angarak Posted June 30, 2006 Author Share Posted June 30, 2006 Yes Martin, J-Spec 6 speed (V160). Is this normal then? Quote Link to comment Share on other sites More sharing options...
Guru Posted June 30, 2006 Share Posted June 30, 2006 Yes quite normal to rattle a little. If you think its worse than the norm try changing gearbox oil or it could be your flywheel...... Quote Link to comment Share on other sites More sharing options...
Angarak Posted June 30, 2006 Author Share Posted June 30, 2006 Thanks, I'll keep an eye (or rather an ear) on it. Will probably change the oil just to be safe. Quote Link to comment Share on other sites More sharing options...
Jake Posted June 30, 2006 Share Posted June 30, 2006 Let me guess 6 Speed?That's amazing! How did you guess his "95 RZ TT" with a clutch was a six speed? Any tips for lottery tomorrow, oh Mystic Martin? Simon Apparently uprated clutches and/or lightened flywheels often make a rattle when the the clutch pedal is down. Mine does it too. I was told it's something to do with 'push' type clutches rather than the stock pull type ones (or was it the other way around?) Anyway, that and a lightened flywheel, which causes the gearbox to rattle, make for a noisy old drivetrain. Quote Link to comment Share on other sites More sharing options...
