Rattle when changing gear
Angarak
Is it normal to hear a rattle from underneath the car when you change gear?
It seems to be more noticeable when shifting into lower gears. I believe my car came with an uprated clutch but Im not sure if it has the OEM or aftermarket flywheel - I think its OEM as it doesnt rattle on tickover.
Any ideas gratefully appreciated.
Simon
Let me guess 6 Speed?
That's amazing! How did you guess his "95 RZ TT" with a clutch was a six speed?
Any tips for lottery tomorrow, oh Mystic Martin? :D
Simon
Apparently uprated clutches and/or lightened flywheels often make a rattle when the the clutch pedal is down. Mine does it too.
I was told it's something to do with 'push' type clutches rather than the stock pull type ones (or was it the other way around?) Anyway, that and a lightened flywheel, which causes the gearbox to rattle, make for a noisy old drivetrain.
