albundy68 Posted January 30, 2004 Share Posted January 30, 2004 im plannin on givin the TT a bit of TLC before i put her back on the road, (she's been hybernating for the last 9 months or so - long story...). What will i need for a service, its a little more complex than a A or B, coz she hasnt really been serviced since import, on about 38K and from what i can make of the crazy jap service book i think shes had 3 services over there. Im thinking, oil change, coolant, oil/fuel filter, new brakes goin on so pads n fluid to be done, will it need new auto box fluid??? what about cam belt? umm, anything else ive forgot??? i kind of want to take care of everything because im not sure whats been done in jap land... Link to comment Share on other sites More sharing options...
albundy68 Posted February 2, 2004 Author Share Posted February 2, 2004 oooplah! cummon, its not the most glamourous of subjects i know, but sumone must know a little about servicing... it'll need plugs i expect as well as the list above, but can anyone think of owt else that might need looking at??? Link to comment Share on other sites More sharing options...
SimonB Posted February 2, 2004 Share Posted February 2, 2004 Diff and gearbox oil change and maybe power steering fluid, although I don't think you really need to do that lot until 6 years or 60000 miles ish (can't remember exactly, the schedule is on http://www.mkiv.com under technical articles / manuals somewhere). Link to comment Share on other sites More sharing options...
osso Posted February 2, 2004 Share Posted February 2, 2004 To give you an idea what i had done for a major service last week.. Engine Oil (Drain & Replace) Oil Filter (replace) Engine Coolant (full flush & replace) Differential Oil (Drain & Replace) Gear box Oil (Drain & Replace) Fuel filter (replace) Auxiliary belt (replace) Cam belt (replace) Body/Chassis nuts & bolts (inspect) Exhaust pipes/mountings (inspect) Steering linkages (inspect) Rack & Pinion assembly (inspect for leakage) Ball joints & dust covers (inspect) Drive shaft boots (retorque flange bolts) you may wanna change your spark plugs as well.. i didnt bother with mine cuz i had new ones put in a couple of months ago.. Link to comment Share on other sites More sharing options...
crimbo Posted February 5, 2004 Share Posted February 5, 2004 Cam-belt is a definate at 60,000 so you got a while yet. check the clutch fluid too but only change it if it's mega sh@gged, coz sometimes if it's thick it seals up any leaks, and there aint no point aiming u're wee at the bucket when it's got a hole in it eh? Link to comment Share on other sites More sharing options...
dude Posted February 6, 2004 Share Posted February 6, 2004 Originally posted by crimbo Cam-belt is a definate at 60,000 so you got a while yet. check the clutch fluid too but only change it if it's mega sh@gged, coz sometimes if it's thick it seals up any leaks, and there aint no point aiming u're wee at the bucket when it's got a hole in it eh? Belts dont just get changed on mileage guys !!!!!!! they are a perishable item and degrade over the years as a mate of mine found out when he took his ferrari for a service , it had done undr 1000 miles but was 8 or 10 years old , he bought it took it to a main dealer and said 'do whatever it needs' it got a major 'revision' every belt , fluid,hose and brake component was changed !!! Dude:flame Dev Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2004 Share Posted February 6, 2004 The place that tunes my car checked my timing belt when I had some work done recently and found that the belt was showing signs of wear and needed changing, this was despite having it changed only 2 years (20K km) earlier. They advised me that it would be better to fit a stronger aftermarket belt to cope with the higher bhp. I went with what they advised and they changed all the belts for higher spec ones. I can't remember the brand of the belts but if anyone wants the info I can find out. Link to comment Share on other sites More sharing options...
dude Posted February 6, 2004 Share Posted February 6, 2004 Originally posted by Nic The place that tunes my car checked my timing belt when I had some work done recently and found that the belt was showing signs of wear and needed changing, this was despite having it changed only 2 years (20K km) earlier. They advised me that it would be better to fit a stronger aftermarket belt to cope with the higher bhp. I went with what they advised and they changed all the belts for higher spec ones. I can't remember the brand of the belts but if anyone wants the info I can find out. Nic i would be very interested to know what belt they fitted , ive never heard of any issues with the stock belt but it may come in handy!!!! Dude:flame Dev Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2004 Share Posted February 6, 2004 Dude, the belts are made by a company called 'Power' there is a bit of blurb about them on the link below. http://www.jt-imports.com/Power_Super_Strong_Belts.htm Trust also do belts http://www.trust-power.com/02greddy/timing_belt.html Link to comment Share on other sites More sharing options...
Kevin Huntley Posted February 6, 2004 Share Posted February 6, 2004 That looks like the "power enterprise" Timing belt. I believe they do a strong timing belt and a super strong timing belt. Cheers Kevin Link to comment Share on other sites More sharing options...
Nic Posted February 6, 2004 Share Posted February 6, 2004 That's the one http://www.power-enterprise.co.jp/ Link to comment Share on other sites More sharing options...
