On a single .. SAFC & EM Experience
Clarkey
Now that sounds really good... Whats the difference in cost?? Is it harder to setup?
I think if I had a T61 DBB instead of just a T61 .. from what I know - it wouldn't have made the mapping job harder. Of course, a T61 map is going to be abit different to a T61 DBB map.
But - I think my 550's would comprise me on a T61 DBB.
As for cost ... not a clue. You'll have to ask mate.
  • Replies 82
I wouldn't expect to pay no more than £200. The reason is - that the SAFC-2 is pretty easy to understand.
It's not as complicated as the EM, EMU etc. All it would get used for would be adjusting the voltage .. for trimming fuel in % across user-defined RPM points.
The S-iTC .. you'd use some det can's and then twiddle 4 or 5 push-out knobs .. :) ... which correspond to RPM points .. when the engine is under load.
You may well be right mate
Bijal
How long with Road and Dyno do you reckon to do this set-up mate?
Cheers
Guest Bijal
Bijal
Cheers
pm me for prices dude.
let me know what management you will want tuning and i'll price it up for ya.
for safc it wont cost much. hks units we dont have the access keys to and dont tune them. aem ems - no problem :cool:
regardless if you want it tuning or not, if your not sure or need help paul, i'm always a phone call away :stickpoke
Wicked, thanks for that. I am looking at 650's, maybe the t61dbb would be a better decision.
Thanks Bijal
Will give you a shout next week
Cheers
Excellent write up Clarkey. The new SAFC neo looks a great buy too, +/- 50% on the fueling, and has the same user definable 16 point rpm settings (lo and Hi) which is handy as most poeple dont tune below the 3K mark anyway, which leaves plenty of scope. I dont know if it also has the same A and B maps for both Hi and Lo settings as the SAFC2 did which was handy when tuning for 2 different Hi boost settings. I defo like using the SAFC though, very easy to use and get the hang off, and great even for things such as raising Fuel cut on KV based systems.
Though i definately recommend trying to get your hands on an ITC, especially if you need to pull any large numbers if running bigger injectors to compensate for the effects on ignition timing.
Theres also a great Mod where instead of using your TPS, you can use the MAP sesnor (same 0-5v) as input thus letting you tune fuel via boost/rpm instead of throttle. Dont know if anyone has tried this on the Supra yet though.
Marty
Ah, didn't know about that kit. :cool: What kind of price would that be ?
It would be interesting to see a dyno chart for the same car .. one with SAFC-2 & the other Neo.
The AFR curves should be abit smoother and more accurate on the Neo.
Marty
Yeah, I remember reading about that Mod .. on some other forum. It wasn't mkiv-owners, this one, supra-forums. It was another generic car club forum. It was basically that the SAFC-2 would read the boost sensor .. I think. You've explained better than I ;)
I remember reading the thread - and he tried it out. And on his setup it didn't work that well.
Unfortunately - no body else in the thread had his setup .. so, couldn't tell if the problem was:
a) The Mod
b) His car - something else.
Let me look through my browser history .. maybe it'll still be there.
Seem to be going for around the £220 + P&P on ebay, so think Nic could probably match that.
They arnt out that long, but noticed they also incorporate the VTECH function of the VAFC which could be handy for switching the likes of water/meth or Nitrous via a map :sly: :rolleyes:
a) The Mod
Its been run Sucessfully on Talon's and 3sgte's clarkey.....do a google for safc boost mod, should throw it up. I can remember Robert Pina doing it years ago on the 1st blue safc, so no doubt its been cracked by now :blink:
Marty
il be testing a Neo out next month, may test in on a 2jzgte and see how well it works using the boost Mod. Also wanna look at the Vtec function to see how easy it is to activate a relay via the vtec map which would be handy for water/meth triggering and depending on how complex it is, may be abble to do progressive controlling of NOS :-)
It be interesting if Paul Mac.. who has a SAFC-2 could try this on his setup.
interesting reading Clarkey, but i'me afraid not a chance on the above mate, SAFC is password protected by Thor to keep spanner monkeys like me making an arse out of it lol and i havn't got a wideband, for info safc and itc cost £140 to map at Thor
Guest Bijal
Marty
the aem has a similar feature to this but its not always advised to use this unless you know how to rig in the safety features within the software.
it can be a good tool and also a bad one at the same token.
bijal
yes, this is obvious and more obvious trimming on larger injectors.
but i am trying to point out methods of ways of tuning the safc2 to suit your driving style if its not given to a mapper.
good thing for the end user is that there is no need to worry about timing maps withthe safc2 becasue the stock ecu is clever enough to do this for ya :cool:
where as on an e-manage or stand alone ems you'd need det cans, addtional external equipment to map the car on fuel and ignition etc. either way, its very good learning for anyone interested in this field.
bijal
Interesting assertations there and elsewhere in this thread. A couple of questions:
What happens if the driver doesn't behave the way he 'should', or say the car is driven by someone with a different style?
How come the stock ECU is 'clever' enough to manage timing adjustments on a single turbo conversion with an sAFC attached, but not clever enough to do that with any other unit?
How do you map for 1.4bar of boost (or more) with an sAFC without 1.2bar going mad rich? Say your boost controller runs wastegate (0.9bar), 1.2bar, and 1.4bar.
-Ian
-Ian
That's true Ian. I had the same problem - could get it fine for WOT - 1 Bar. But on moderate boost - it ran overly rich. It's compromise ... because .. your limited on - RPM points, and choosing between mapping (with the mod installed and working)
@ Throttle
OR
@ Boost
But not both.
I guess - because of the 12 point map - you have to compromise AFR's @ RPM points. That was my issue.
If I had maybe 20 rpm points - I think I could've done it.
Ah that's shame. But Paul, If you can pick up an SAFC-2 at a total bargain ..... might be worth picking it up ..
and then swap the SAFC-2's over. Then map it too boost.
Would be interesting to find out ... it may make mapping on a SAFC-2 more accurate.
Guest Bijal
-Ian
good point ian,
this is where the mapper should always sit down with their client and discuss their aims and goals. in most cases they want the car to be "daily driven" and user friendly so therefore ONLY the mapper would be able to work around that question.
to be honest, in MOST situations the mapper would set the a/f ratios to set target before boost and also after boost, both on low throttle AND high throttle.
