IT Bods - Tape Backup Recomendations...
edd_t
Currently at work and for the last 4 years, my backup solution has been SDLT 120/320. I have a MSL5026 tape library with 2 SDLT tape drives installed.
At the moment I am backing up around 900gb every night, with compression i get it onto 6 SDLT tapes. It takes around 13 hours, which i know is pretty slow.
Can anyone else suggest a newer faster technology with higher capacity tapes.
I'm not up to speed with this sort of stuff at the moment :blink:
Cheers,
Edd..
lol thats what the robotic MSL library if for. great fun watching it pic tapes up and carry them to the drives and stuff.
we have online backup for some data. but need a 2nd copy on tape which gets removed each evening and stored off site. and carrying 6 sdlt tapes every night in my bag is getting annoying.
Perhaps you could back up to a NAS box liek spackrackman says, and run the tape drive locally from there to reduce network congestion.
As for type of drive.. hmm.. it'd have to be S-AIT or LTO I suppose. Can't you cut down the amount you're backing up?
Dont really have to worry about network congestion as the company is closed most of the time the backups run, and it all runs on a seperate LAN using multihomed servers.
900GB is cut down!!! lol.
Cool, I'll check out S-AIT and LTO tommorow, cheers :)
The natural upgrade will be to the MSL6030 bung a couple of Ultrium960 drives in there, jobs a good'un. The 960's take 800GB (compressed) cartridges, so depending on the type of data you're looking at 2-3 tapes per backup (I'm assuming full backup?)
Theoretical max is 80MB/s per drive, although if you're streaming the data via a Windows server then you'll struggle to exceed 25MB/s in my experience.
Should be able to backup ~900GB in a couple of hours (theoretically)
