Couple of Subs and an amp (Rockford/Genesis/Image Dynamics)
DanStwo
Hi guys...
Just wondering if any of you are interested in the audio equipment I currently have for sale?
Rockford 8140 Headunit (circa '95) + changer - £225.00
Fantastic Unit...
Manual - http://www.rockfordfosgate.com/rftech/library/1997/1_Source_Units/
For sale in perfect condition with remote and cd changer
The unit is Rockfords top of the range unit from '95, retailing for £1000 and sounds amazing. In tests in a magazine, it performed better than a Alpine 7939, Pioneer P1 and the other top of the range units in the same year.
Features a single pair of preouts, but will do 8.5v or 17v balanced.
The balanced output is designed to drive the Rockford EPX2 system.
The unit also features a unique Processor Loop, what this means is you can EQ the sound before it leaves the HU, so you can mount your EQ upfront and adjust it upfront.
The unit features an auxilary input as well as the cd changer input (which can be changed to another aux input)
The stereo has 3 remote outputs
1 - Delayed on, quick off - for amplifiers
2 - quick on, delayed off - for EQs
3 - remote controlled pulse
The 3rd remote is a pulse which is sent down the cable when you push the Punch button on the remote, using a relay this pulse can be used to turn lighting on or off or other accessories.
The changer is a 6 disc changer with cable
Rockford Fosgate bd1001 Amplfier - £200
Good condition amp as above...
£200.00 collection prefered.
Will post pics if I get half a chance
Specs -
http://ampguts.realmofexcursion.com/Rockford_Fosgate_1001BD/
Genesis Audiophile A25.01 (10inch Sub) - £150
Nominal Size: 25cm/10�
Recommended Amp Power: 200-500W RMS
Sensitivity: 86dB/1 Watt/1 Metre & 89dB/2.83v /1 Metre
Frequency response: 25Hz-200Hz +/- 3dB
Nominal Impedance: 4 Ohms
Mounting Depth: 121mm
What more can I say.... cracking sub...
Hardly been used. only to test.
Image Dynamic ID10inch V3 Dual 4 ohm Sub - £100
Hardly used and in great condition
Specs -
http://www.imagedynamicsusa.com/pdf/ID10_D4_V3.pdf
http://www.talkaudio.co.uk/gallery/data/500/6339031.jpg
http://www.talkaudio.co.uk/gallery/data/500/6339021.jpg
If anyone is interested let me know either by PM/E-mail or replying in here.
Thanks
