Rolec Posted October 30, 2001 Share Posted October 30, 2001 Did my first proper bit of night-time, round the country lanes driving, since the car has been lowered. Frightened the life out of me !! My dipped seemed to finish about 3 foot in front of me... I've now adjusted them up. Does anyone know where the should be. i.e. parked 2 metres from wall - top of beam 1mtr up wall ?? Thanks Dean.. Quote Link to comment Share on other sites More sharing options...
Phil Wall Posted October 30, 2001 Share Posted October 30, 2001 Dean I had the same problem as you when I first got the car. Posted on the main list but no one took any notice. When the car is MOT'ed the lamps have to be with in upper and lower limits. I suspect yours was at the lower limit, as you have subsequently adjusted your suspension it may have made it worse. I got my friendly MOT tester to stick mine to the upper limit as they were just on the lower limit, dangerous as far as I was concerned. I hardly need to use main beam at all now. A huge improvement, I get flashed regularly as well, so I know they are working.:biggrin: I do have a chart somewhere, I will see if I can photgraph it and send it to you. so you can get close to the correct setting. You need to do the adjustment with some one sat in the drivers seat. (Edited by Phil Wall at 3:29 pm on Oct. 30, 2001) Quote Link to comment Share on other sites More sharing options...
Guest Ash Posted October 30, 2001 Share Posted October 30, 2001 Dean, if you do a search on MOT +UK or something like that, there is a goverment website (or at least I think it is a Gov one) that gives you all the MOT requirements. I used to have the link saved in my favourites folder, but I can't find it at the moment. I had a look at the body-electrical manual but it appears the alignment details are not given for some reason. Yours, J Quote Link to comment Share on other sites More sharing options...
Brian Jackett Posted October 30, 2001 Share Posted October 30, 2001 Just put them as high as you like and gradually lower them until you do not get flashed any more. (Top tip) I have just put a new front spoiler on and mine are the lights are so low I can drive around with main beam on and not get flashed. regards Quote Link to comment Share on other sites More sharing options...
