SuperSupra Posted June 28, 2006 Share Posted June 28, 2006 The Thor TSD and DSC combined unit and the TSD unit on it's own look identical on the website. Is this an error in terms of the picture they put up or do they in fact both say DSC + TSD on them? If they do look the same, how do you know which is which?!!!!!! See here and compare both pictures. It's like spot the difference, except, there are none! Quote Link to comment Share on other sites More sharing options...
Jake Posted June 28, 2006 Share Posted June 28, 2006 Yes they look same nowadays because (annoyingly) they use the same case. The previous versions were quite different, iirc. You can easily tell the TSD from the combined TSD/DSC by inspecting your credit card statement. As far as I know there's no way to determine visually whether a pre-loved Thor unit is a combi-TSD/DSC or just a vanilla TSD. So be careful if offered a 2nd hand one. Quote Link to comment Share on other sites More sharing options...
SuperSupra Posted June 29, 2006 Author Share Posted June 29, 2006 Yes they look same nowadays because (annoyingly) they use the same case. The previous versions were quite different, iirc. You can easily tell the TSD from the combined TSD/DSC by inspecting your credit card statement. As far as I know there's no way to determine visually whether a pre-loved Thor unit is a combi-TSD/DSC or just a vanilla TSD. So be careful if offered a 2nd hand one. Hmmm yeah that's exactly what I got mate, second hand one, paid £45 for it so I'm not really complaining either way! Ah well, I'll fit it (try to fit it) and see what happens eh! Cheers Jake. Quote Link to comment Share on other sites More sharing options...
SuperSupra Posted August 3, 2006 Author Share Posted August 3, 2006 Resurrected thread - does anyone know of a way to tell by looking whether it is a TSD on it's own, or whether I can expect to be converted from kph to mph too? There must be a way, surely? Quote Link to comment Share on other sites More sharing options...
Pete Posted August 3, 2006 Share Posted August 3, 2006 I suspect it's the same chip and just down to the Firmware uploaded. Quote Link to comment Share on other sites More sharing options...
SuperSupra Posted August 3, 2006 Author Share Posted August 3, 2006 I suspect it's the same chip and just down to the Firmware uploaded. Ah I see, that would make sense, although it's gonna be a bugger! If I were to fit it, and find that what I have is a TSD and not a converter, is there another simple device I would need or do I need the combined unit? Quote Link to comment Share on other sites More sharing options...
Prof. Monkey Posted August 5, 2006 Share Posted August 5, 2006 You need the one that does both, circa 100 pounds (where is the pound sign on this damn keyboard?) I have one fitted, from memory it is TSD + DSC its a doddle to fit! Quote Link to comment Share on other sites More sharing options...
Pete Posted August 5, 2006 Share Posted August 5, 2006 I feel you're better off with the combined unit as there's less wires and sell your existing unit seperately. (should it turn out not to do the trick of course) Quote Link to comment Share on other sites More sharing options...
