180mph na supe ?
Jurgen-Jm-Imports
  Lucifer-mkivstore.com said:
Just out of interest what do you guys think an NA will do if tuned correctly?
Theres been a thread where this was discussed recently, I think it was said that the becuase of the NA Transmissions gearing it would be limited to around 170ish (may have remebered wrong, will check to be sure)
  Suprash said:
Is that not a turbo timer on the top of stearing column ??
Turbo timers are still good for an NA engine arnt they? i know its not what they are made for, but a bit of cool dow time for any engine is appreciated. :)
Edit: it does have the 3 spaces below the stereo tho, hmmmm....
  adam5284 said:
the guy selling it has hidden his feedback, why? less than 70% positive!! Chump!
Member Profile: beryl7255
Positive Feedback: 69.2%
Members who left a positive: 9
Members who left a negative: 4
All positive feedback received: 10
What a tit.
But that depends on the redline eh?
The only reason I say is because Im currently building the MKivStore Car Garage and a high revving NA is in the lineup.
I can't see why you couldn't get 350bhp out of an NA. You'd need some seriously naughty cams, balanced and lightened everything, loads of compression and some headwork I'd have thought. It's still a three litre engine after all so you have something to work with.
G-Force/DSA got 250bhp out of an n/a MR2, and it was almost as quick as my MR2T.
  Pneumoni said:
mines an NA and it has a turbo timer,.
its realy annoying, ill give it to anyone that can correctly and safely ( in a proffesional manner ) remove it for me ;)
I remember seeing that. I thought it wasn't connected up though..
