I broke down :-( help please...
scooby_doo_do
After being stuck in my car since 11:30pm last night, the AA finally managed to get me a flat bed trailor that i could drive straight on to at 7:30am.. Thats after sending 3 other lorrys that couldn't get me on.. So 8 hours sitting it out.. Well done AA.
Nice..
Problem :
I was doing about 30mph and a cat ran out in front of me, so i anchored on the brakes very hard and i missed the cat... The engine didn't seem to accelerate anymore and i thought i was in the wrong gear.. So changed again this time the engine had cut out completly and i was left rolling with no power steering..Came to complete stop.
Alarm on and off... Tried restart.. The car started for a second or 2 went to 1k rpm and dropped and cut out again... Tried this 1 more time and same thing.
Disconnected battery and ecu fuses... Waited 15 minutes.. tried again... Same thing... Engine starts and stops.
After 6 hours of hazard lights being on,,,,tried again but this time it just tried to start and no ignition...
Question...
Any ideas.... ? Has it gone to supra heaven? Is there an emergency fuel cut off somewhere? should i go to bed now?
Many thanks.
Craig.
1) Check for a fault code! Chances are something electrical has poped off and the ECU has picked it up
2) Check the coil pack connectors-The little clips that connect to the coil packs under the spark plug cover.
same thing happen to me when I braked hard- one came loose.
ok.. I've checked the passenger footwell and tried my hardest to see amongst the thousands of wires if any had come loose at i can't see anything. When i try to start the car it just turns but doesn't start at all now :-( not sure if this is partly due to the battery being dead.. I'll have to wait until tommorrow when it should be charged.
I'll go and check the IC pipes now chris :)
Have you checked your EFI fuses under the bonnet?
I had a problem once, loose connection blew one of the EFI Fuses.
Same thing, engine would turn over but no fuel being pumped.
The fuse that had gone actually looked fine, it was only when i replaced them with new ones that it solved the problem!
Worth a check.
Before you go out buying stuff let's see if we can diagnose the problem first :)
If you put a jumper wire between +B and FP in your diagnostics port, then key on the ignition (but don't try to start the car), your fuel system should fire up. You can clearly hear it without the engine running, a suprisingly loud swooshing. If it doesn't fire up, your pump is dead. If it does, it's probably electrics, as this diagnostic bypasses the fuel pump ECU and some other bits.
-Ian
I say fuel pump / fuse to fuel pump or wiring to pump.
When you put the ignition on you can test the wiring out the top of the pump hanger for electrical feed before removing the pump hanger etc etc with a multimeter.
If you are getting current then take the hanger out, unplug the pump and test the + / - of the plug.. If you are seeing current there your pump has died.
Obviously dot do this if you can hear the pump and its working but if your not getting fuel at the rail im 99% sure its the pump
