Took my PC apart tonight.
Class One
As i'd incorrectly enetered a flashcard and it fell inside the driver.
I've had the thing for about 30 months and it's on all the time except when I'm away.
Fook me the dust inside the thing! I'm surprised it still bloody works! Grim!
A gentle clean out with the dyson and its spick and span.
Aaaagh!....you got away with it!...
Don't ever put a vacuum cleaner nozzle near your computer mate, you'll kill it dead....
Apparently the static voltages, even on the end of a plastic hose, can fry your motherboard...
Use a dry paintbrush and something like Air Duster aerosol if you want to blow the cobwebs out....:)
you will be fine with a dyson as long as you dont use any metal attachments,the hose and pipe are rubber and thus dont conduct electricity, but the paint brush and aerosol is a much better solution:)
Guest gzaerojon
it doesn't have to be metal to conduct as its static
my service vac i use has a rubber hose with a plastic attachement and has an earth conected to the hose
still blows stuff up :(
i wouldn't use a vac
I can remember getting enough shocks from rubber plug caps in my youth...before I learned not to touch the bodywork with my other hand..:)
Guest gzaerojon
lol been there, testing for a spark on my motorbike and my head to close to the handle bar
spark jumped from my head :innocent: bl00dy hurt too :D
if that was the case m8 there would be a lot of dead people in the world as rubber is used as an insulator!!! static elec is still elec and will NOT pass through rubber..it may jump from one conductive material to another as static elec is usually thousands of volts
No it doesn't have to be thousands of volts as you have no doubt experienced yourself when you get a belt after getting out of a car when you touch the bodywork...
The whole point about static is that it can exist in air..
So you switch on your hoover, what is passing down the center of the hose?,,,dust particles and air (damp or otherwise) which is being drawn by an electric motor...
So the air is being drawn up the pipe directly to a 240 volt motor at a fair rate of knots, but not quite as fast as electricity is capable of traveling...work it out for yourself...:)
Think we're missing the actual facts here. Its not about whether the vacuum hose/nozzle etc conducts electricity. It is the objects ability to gain an electrical charge that matters here...
ANY material has the ability to gain and hold a static build up of electrical charge. (and plastic/rubber is VERY good at holding this charge as it is an INSULATOR and therefore cannot dissapate its charge easily)
You know this as if you rub a baloon against your hair you can stick it to a wall or rub a nylon stick with a cloth (remember the old bending of water trick in Science!! :p ) And both baloons and nylon are rubber and plastic!!!
By rubbing the object you are either 'rubbing off' electrons or 'rubbing on' electrons to the object. The object therefore gains a net electrical charge. (i.e. a build up/deficit of electrons at the objects surface) and this charge will transfer to an object to balance its charge.
To put this in context with the hoover thing... You turn on the dyson, the air quickly travels through the nozzle and 'rubs' electrons off the plastic, leaving the nozzle with a positive electrical charge. (you also have a spinning motor that also generates more charge within the hoover).
Now, when you put this static charged nozzle near the computer it can discharge through the motherboards circuitry which toasts any microelectronics it passes through.
phew.... now my brain hurts... time for bed!
PC's are like hoovers, gather so much dust it's not funny anymore.
:yeahthat:
As a hayfever sufferer since a few years ago I've always added pollen filters before the large intake fans on my PC case. Just turning the PC can clear the room of pollen and house dust in less than 20 minutes, very nice in the middle of summer when you need some relief from hayfever!
I think static is over rated I mean they say you need anti static mats/bands etc I have built around 20 PC's now and my own one is always in bits I never use any anti static stuff just the bags and never had a problem.
Dust inside the case is a cause of not having good air flow through the pc
pish. I've vacuumed and built/serviced PC's and components thousands of times when I used to do it for a living (these day's I try not to get my hands dirty ;)), I'd never used an anti-static wrist band or anything and have never fried anything (I would touch the metal casing of the power supply to discharge any static I may have though, just to make sure).
Don't worry about it :)
I wouldn't recommend plugging PCI cards in while it's still switched on though, didn't do that again.
Also, don't push a pipe cleaner into two for the three ports on a PSE cord - black fingers and lots of flashes :D
Also (on a serious note) NEVER EVER EVER where an anti-static band when working on a monitor, you WILL die!!
