ad500 Posted January 26, 2004 Share Posted January 26, 2004 Thats alot better, i need reminding every now and then:D Link to comment Share on other sites More sharing options...
Supragal Posted January 26, 2004 Share Posted January 26, 2004 Originally posted by ad500 Thats alot better, i need reminding every now and then:D Not as much as me I promise you Link to comment Share on other sites More sharing options...
Suprash Posted January 27, 2004 Share Posted January 27, 2004 You think the 6spd feels close together, the NA's gears are even closer. when I get back in my TT is feels like a football field inbetween gears. Which is strange, I would have thought the more gears you have, the closer the gears will be..... Link to comment Share on other sites More sharing options...
Paul R Posted January 27, 2004 Author Share Posted January 27, 2004 Hi, I've had a mess about with changing gear today and I think the problem is the following: The 'catch' that stops you putting the car into reverse seems to be broken, hence it lets you put the stick too far to the right. It's like the catch is always up. Anyone know how this mechanism works? is it possible to fix? Cheers, Paul. Link to comment Share on other sites More sharing options...
Kopite Posted January 27, 2004 Share Posted January 27, 2004 lol Picasso eat your heart out hope you get it sorted mate! Originally posted by Paul R This pic is the best way to describe it! Link to comment Share on other sites More sharing options...
Paul R Posted January 27, 2004 Author Share Posted January 27, 2004 Originally posted by scally_kopite7 lol Picasso eat your heart out hope you get it sorted mate! It's not too much of a problem. More annoying! Paul. Link to comment Share on other sites More sharing options...
Dragonball Posted January 27, 2004 Share Posted January 27, 2004 Paul - Dude is going to check out which catch that is tomorrow (he has someones manual in) and we'll try and get hold of one for you Probably easy to fit Link to comment Share on other sites More sharing options...
Paul R Posted January 27, 2004 Author Share Posted January 27, 2004 Originally posted by Paul E Paul - Dude is going to check out which catch that is tomorrow (he has someones manual in) and we'll try and get hold of one for you Probably easy to fit OK, cheers, The catch moves up and down but does nowt! I havent pulled the rubber off the gear stick yet to have a look, maybee it's something down there. Paul. Link to comment Share on other sites More sharing options...
mr_maj Posted May 1, 2005 Share Posted May 1, 2005 This is a bit late but what happened with this Paul R? Ive got same problem going from 5th to 6th! Link to comment Share on other sites More sharing options...
Dragonball Posted May 1, 2005 Share Posted May 1, 2005 He defected to the scooby's - but I think he will be back one day! The force is strong in this one! Link to comment Share on other sites More sharing options...
ewizzy Posted May 1, 2005 Share Posted May 1, 2005 didnt someone else have a similar problem when they had the clutch changed or, a quickshift added or something? basically, when it was put back together, the thing that holds the lever in place properly, (if you take the gator off the thing thats held on with 4 bolts like a square shape) was put on upside down, stopped the liftyuppy thing from doing anything, and it felt like it would go into reverse (although, I am sure the synchro rings would probably prevent this from actually happening, unless you REALLY force it) I'll have a quick search and try and find the original thread.... HTH Alex Link to comment Share on other sites More sharing options...
ewizzy Posted May 1, 2005 Share Posted May 1, 2005 Found it...... http://www.mkivsupra.net/vbb/showthread.php?t=36552&highlight=Lift+clutch+reverse Link to comment Share on other sites More sharing options...
mr_maj Posted May 1, 2005 Share Posted May 1, 2005 mine has to be lifted to engage reverse but theres a grind when going from 5th into 6th, this is the only time it does it. Link to comment Share on other sites More sharing options...
Kopite Posted May 1, 2005 Share Posted May 1, 2005 he's just finished rebuilding an MR2 turbo, he sold the scooby type r he got, got an audi a6, he sold that about a week later and has now got a silver UK impreza (i think)....... but i think he's sold that now the MR2 is almost done....... i give up!! he's worse than a woman!! Link to comment Share on other sites More sharing options...
J4CK50N Posted May 2, 2005 Share Posted May 2, 2005 hes still go the impreza at the moment. MR2 is nearly done hes just sorting a few teething problems with it now!!! He should never have sold the Scoob type R!! I still miss it sometimes! :D Link to comment Share on other sites More sharing options...
Paul R Posted November 28, 2007 Author Share Posted November 28, 2007 You bunch of poofs!!! wow, they were talking about me 2 years ago....how sweet Paul. Link to comment Share on other sites More sharing options...
AndrewOW Posted November 28, 2007 Share Posted November 28, 2007 'Holy Thread Resurrection Batman' as the saying goes! I've just read all that. Did you get your gearbox problem sorted out at all? Link to comment Share on other sites More sharing options...
Ady Posted November 28, 2007 Share Posted November 28, 2007 sticky second gear changes when cold could be down to the gear box oil. there is a thread on it in the guides section. Might be worth changing the oil? Link to comment Share on other sites More sharing options...
Paul R Posted November 28, 2007 Author Share Posted November 28, 2007 'Holy Thread Resurrection Batman' as the saying goes! I've just read all that. Did you get your gearbox problem sorted out at all? A plate was missing off of the shifter surround - as a quick shift had been fitted before I had the car and then it had been removed, but they didnt put the old plate back. The plate stops the gear stick from going over to the right when changing gear. I got one in the end and fitted it, problem solved Paul. Link to comment Share on other sites More sharing options...
