gear shift in a 6sp TT j-spec
Paul R
Hi,
I've had a mess about with changing gear today and I think the problem is the following:
The 'catch' that stops you putting the car into reverse seems to be broken, hence it lets you put the stick too far to the right. It's like the catch is always up.
Anyone know how this mechanism works? is it possible to fix?
Cheers,
Paul.
Originally posted by Paul E
Paul -
Dude is going to check out which catch that is tomorrow (he has someones manual in) and we'll try and get hold of one for you
Probably easy to fit
:thumbs:
OK, cheers,
The catch moves up and down but does nowt!
I havent pulled the rubber off the gear stick yet to have a look, maybee it's something down there.
Paul.
  • 1 year later...
didnt someone else have a similar problem when they had the clutch changed or, a quickshift added or something?
basically, when it was put back together, the thing that holds the lever in place properly, (if you take the gator off the thing thats held on with 4 bolts like a square shape) was put on upside down, stopped the liftyuppy thing from doing anything, and it felt like it would go into reverse (although, I am sure the synchro rings would probably prevent this from actually happening, unless you REALLY force it)
I'll have a quick search and try and find the original thread.... :thumbs:
HTH
Alex
he's just finished rebuilding an MR2 turbo, he sold the scooby type r he got, got an audi a6, he sold that about a week later and has now got a silver UK impreza (i think)....... but i think he's sold that now the MR2 is almost done....... i give up!! he's worse than a woman!! :limp: :D
  • 2 years later...
'Holy Thread Resurrection Batman' as the saying goes!
I've just read all that. Did you get your gearbox problem sorted out at all? :)
A plate was missing off of the shifter surround - as a quick shift had been fitted before I had the car and then it had been removed, but they didnt put the old plate back. The plate stops the gear stick from going over to the right when changing gear.
I got one in the end and fitted it, problem solved :)
Paul.
