Pete Posted June 23, 2006 Share Posted June 23, 2006 Anti-lock Brake System and safety precautions... The Anti-Lock Brake System (ABS) consists of hydraulic unit, brake actuator, actuator solenoids, lateral acceleration sensor, pump motor, ABS Electronic Control Unit (ECU), indicator light, and 4 wheel speed sensors. See Fig. 1. An ABS indicator light, located in the instrument cluster, comes on for 3 seconds as a bulb test when ignition is first turned on. A primary check is performed after each engine start and initial time vehicle speed exceeds 6 MPH. An actuator noise is heard during this period of time. This is normal.anti lock brake safety precuations.pdfanti-lock-brake-system.pdf Quote Link to comment Share on other sites More sharing options...
Guest kanekane Posted October 23, 2011 Share Posted October 23, 2011 Wow nice litterature ! Quote Link to comment Share on other sites More sharing options...
