Pete Posted June 23, 2006 Share Posted June 23, 2006 Brake system... The hydraulic brake system uses a tandem master cylinder with a vacuum power assist servo. All models are equipped with 4-wheel disc brakes. A proportioning valve is used to regulate brake pressure between front and rear brakes. Parking brake lever mechanically activates rear brakes. Parking brake is a duo servo mechanical drum brake design built into bell of rear rotor assemblies.brake system.pdf Link to comment Share on other sites More sharing options...
