does emanage blue have a fcd built in or will i need to buy one seperate
mikeyh
The EMB is always throttling the signal back because you've got bigger injectors and you want them to open for less time so as the voltage is pegged back in this way you won't need fuel cut till you get towards maaxing out the bigger injectors.
For future reference (anyone getting this in a search) The FCD function of the EMB does not work on UK spec cars (maybe VVTI too).
This is due to the UK having a MAF, which is what the EMB alters for the airflow map and the fuel cut running off the MAP sensor.
Anything over 4.44v = fuel cut. That means the stock ECU is seeing over 1bar of boost. At 0.98bar boost it runs the injectors at 100% duty. Ergo, if you are seeing fuel cut then your injectors are at 100% duty. This is why you shouldn't need any form of fuel cut defense with bigger injectors, because you are pulling enough airflow signal to trim your injectors back that you don't even get near a 0.98bar reaching the ECU.
If you ever need 100% duty cycle then a) you'll need the FCD function and b) you chose poorly on the injector front ;)
It doesn't hurt to leave it in though, every map I've done has got it set to 4.40v.
UK specs you just pull the vac hose off the MAP sensor, as Alex says :) And, obviously, block it up.
-Ian
