ManwithSupra Posted June 22, 2006 Share Posted June 22, 2006 Are these the spec of the front uk spec TT discs ? Disc diameter 323.0mm Disc thickness 30.0mm Or could someone check ? Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted June 22, 2006 Author Share Posted June 22, 2006 anyone know Quote Link to comment Share on other sites More sharing options...
Nic Posted June 22, 2006 Share Posted June 22, 2006 Diameter is definitely correct, I believe the width is right also, but not 100% sure. Quote Link to comment Share on other sites More sharing options...
garethr Posted June 22, 2006 Share Posted June 22, 2006 According to the DBA catalogue (and they are one of the few sites to have the correct info for the Soarer TT) http://www.dba.com.au Diameter 323mm Overall Depth 50mm Width 30mm Wear limit 28mm Centre Hole 62mm Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted June 22, 2006 Author Share Posted June 22, 2006 Do they have the same brakes as the Uk TT Soops Quote Link to comment Share on other sites More sharing options...
garethr Posted June 22, 2006 Share Posted June 22, 2006 Do they have the same brakes as the UK TT Soops? No, but they'll fit The Soarer TT and the V8 with active suspension have the same size front discs as the J-Spec JZA80. A number of sites list the same sizes for all Soarers, but the other V8s and the 3-litres have smaller brakes. Just meant that DBA seem to list accurate info. Quote Link to comment Share on other sites More sharing options...
Sharpie Posted June 22, 2006 Share Posted June 22, 2006 Ark on here has DBA's (I think) on his soop with UK/bigger brakes - here is a photo of them anyway. Drop him a pm ? Quote Link to comment Share on other sites More sharing options...
