stevie_b Posted December 5, 2006 Share Posted December 5, 2006 My Odometer still increments the miles, so does this mean the speed sensor is OK and that the most likely culprit is the Odometer circuitry? Yep, sounds like it. If you're sure you've wired in the speed converter OK (and if the odo is incrementing, it sounds like you have), then a flaky odo unit is the most likely culprit. Link to comment Share on other sites More sharing options...
Angarak Posted December 5, 2006 Share Posted December 5, 2006 Cheers Link to comment Share on other sites More sharing options...
wwe Posted February 6, 2007 Share Posted February 6, 2007 i dont have a coverter on the car i do have one just not fitted yet would this still work 4 me Link to comment Share on other sites More sharing options...
stevie_b Posted February 7, 2007 Share Posted February 7, 2007 i dont have a coverter on the car i do have one just not fitted yet would this still work 4 me Sorry mate, I don't understand you there. Could you re-phrase it please? Link to comment Share on other sites More sharing options...
Supraman Posted May 26, 2007 Share Posted May 26, 2007 Just a quick update...after enduring this issue for almost two years took the car to Envy and they resolved it within a day!!! Wish I had gone there at the start. Needless to say I would recommend anyone with the same problem to contact Envy to have it resolved. Link to comment Share on other sites More sharing options...
stevie_b Posted May 27, 2007 Share Posted May 27, 2007 Do you know what they did? Link to comment Share on other sites More sharing options...
MarkTheBoy Posted May 27, 2007 Share Posted May 27, 2007 Where are envy based again? Link to comment Share on other sites More sharing options...
Supraman Posted May 28, 2007 Share Posted May 28, 2007 stevie b - took wiring back to stock and in the process found some duff wiring! MarkTheBoy - 30 mins north of Newcastle. Check out the traders section. Link to comment Share on other sites More sharing options...
Jspec Germany Posted May 28, 2007 Share Posted May 28, 2007 I can't just jump in the car and drive to Envy. Mine had the code 42 without the delimiter and I've apparently wired the TSD incorrectly because the car's still limited and the code 42 still there. Hopefully, I'll be able to fix it when I rewire. Link to comment Share on other sites More sharing options...
stevie_b Posted May 29, 2007 Share Posted May 29, 2007 JSpec: fixing the code 42 problem and wiring in a TSD are 2 separate jobs. Depending on the root cause of your code 42, I think some TSDs can fix the code 42 problem as a side-effect of installing them. I know my Thor TSD+DSC did. However, I realise that you don't want a DSC. What make of TSD have you got? If it were me (and apologies if you've already tried this), I'd remove any TSD you've got fitted, and simply bypass the odo buffering circuit (instructions around here somewhere on how to do this). Take it for a drive, and see if it fixes the code 42. If it doesn't, at least you know you need to look elsewhere (possibly the ECU connections). If it does, re-fit the TSD, making sure the fitting instructions don't re-instate the buffer circuit. Some people don't like to chop into the wiring loom, but as long as you work neatly, any chops you make will be completely reversible with a bit more soldering and some electrical insulating tape. Let us know how you get on. Link to comment Share on other sites More sharing options...
Jspec Germany Posted May 29, 2007 Share Posted May 29, 2007 JSpec: fixing the code 42 problem and wiring in a TSD are 2 separate jobs. Depending on the root cause of your code 42, I think some TSDs can fix the code 42 problem as a side-effect of installing them. I know my Thor TSD+DSC did. However, I realise that you don't want a DSC. What make of TSD have you got? If it were me (and apologies if you've already tried this), I'd remove any TSD you've got fitted, and simply bypass the odo buffering circuit (instructions around here somewhere on how to do this). Take it for a drive, and see if it fixes the code 42. If it doesn't, at least you know you need to look elsewhere (possibly the ECU connections). If it does, re-fit the TSD, making sure the fitting instructions don't re-instate the buffer circuit. Some people don't like to chop into the wiring loom, but as long as you work neatly, any chops you make will be completely reversible with a bit more soldering and some electrical insulating tape. Let us know how you get on. Ok Steve, thanks. I figured that was the case. I hear the most common culprit is dry solder joints on the odometer or the the output speed signal from the odometer being bad. Can't do it today, I had to fly and am already into the beer. Link to comment Share on other sites More sharing options...
wisc Posted June 16, 2007 Share Posted June 16, 2007 WAAAAAAAIIIIIIITTTTTT!!!! before you cut anything READ: I've just completed this and happy to say my cruse is once again working! BUT, there is no need to cut the pink wire, with a bit of fiddling round its not to hard to remove the pin from the harness and wedge it in the harness with the blue wire (for those of you who are perfectionists just use a glob of solder down there to hold it in firm and it will still be easy to remove later ). Don't stress to much if you break the pin as you should be able to get another one from dick smiths (radio shack?) or the likes. i just used a tiny screwdriver (or a pin should even do it) squash the top of the end (the side that plugs into the ODO) of the pin in the harness and it should slide out. If the end breaks you can crimp another end on later as long as you get it out and DON'T forget to reset your ECU! Link to comment Share on other sites More sharing options...
wisc Posted June 17, 2007 Share Posted June 17, 2007 scratch that, over drive light is still flicking and code 42 is back, at least it fixed the cruise control not working issue..... must have another problem too. after visually inspecting the odo it looks in decent condition. any other ideas? the unplugging the pink wire as ive said above still works though.. would rather do that than cut the wire. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 17, 2007 Share Posted June 17, 2007 This is the fix i did and all my troubles went away Link to comment Share on other sites More sharing options...
stevie_b Posted June 17, 2007 Share Posted June 17, 2007 This is the fix i did and all my troubles went away Sounds about right Matt. I think this is what I said in post #39, but you've said it a lot clearer than I did! -> If I'm correct, what you'll need to do is strip some of the insulation on the pin 5 wire, cut the wire to pin 6, and solder the loom side of the "pin 6 cut" to the exposed pin 5 wire. This merely bypasses the buffering of the odo unit. Link to comment Share on other sites More sharing options...
Jspec Germany Posted June 18, 2007 Share Posted June 18, 2007 Does that buffering do anything? Surely it has a purpose. Will my active spoiler still work? What about the speed sensitive power steering? Link to comment Share on other sites More sharing options...
stevie_b Posted June 19, 2007 Share Posted June 19, 2007 Does that buffering do anything? Surely it has a purpose. Will my active spoiler still work? What about the speed sensitive power steering? When fitted correctly, the Thor DSC bypasses the buffer circuit. I don't think anyone's reported any problems caused by installing them. Can't really tell about long-term effects, but they seem unlikely to be caused by this sort of problem/fix. Matt aero top's diagram joins what would be the buffer output (loom side) to the buffer input, whereas the Thor DSC supplies the buffer output (loom side) with a 1:1 (unbuffered unless the Thor unit duplicates the buffer circuit: unlikely) speed signal, and the buffer input is supplied with either a 1:1 signal (if you want the odo to keep counting in kms), or a 5:8 signal (if you want the odo to count in miles from now on). The effect is the same for both changes: the odo buffer output is ignored by cutting the wire and leaving the plug-side unconnected, and supplying the loom-side with a signal derived directly from that supplied to the odo input. I've got an NA so I can't comment on the TT stuff like active spoiler, but my progressive power steering works fine after fitting a Thor DSC. Hard to believe I know, but I'm really not sure what useful purpose the buffer has. If anyone knows, please post it up here! Link to comment Share on other sites More sharing options...
Digsy Posted June 19, 2007 Share Posted June 19, 2007 As I understand it a buffer usually duplicates a signal, but from a source that can supply more current. You only need a couple of resitors and an NPN transistor to make a simple buffer circuit. Its possible that the Odo circuit does some pulse-shaping, too. I did ask a while back if anyone knew what the waveforms looked like pre- and post-buffer. If they are the same shape and don't cross the zero volts line then it might be very easy to make a stand-alone replacement buffer circuit. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 19, 2007 Share Posted June 19, 2007 Does that buffering do anything? Surely it has a purpose. Will my active spoiler still work? What about the speed sensitive power steering? the power steering the was one of the reasons i did this fix as mine was light all the time and playing up Link to comment Share on other sites More sharing options...
Jspec Germany Posted June 19, 2007 Share Posted June 19, 2007 ok, thanks, gonna reinstall at the odometer/speedo. Link to comment Share on other sites More sharing options...
wisc Posted June 20, 2007 Share Posted June 20, 2007 I've done what Matt "Aero top"s diagram shows, however my overdrive light is still flashing, (cruise is fixed) stevie_b you seem to know whats going on, any other ideas? on why im still getting code 42 and the light still flashing, I even reset my ECU which fixed the issue until the drive after next. Link to comment Share on other sites More sharing options...
stevie_b Posted June 20, 2007 Share Posted June 20, 2007 I've done what Matt "Aero top"s diagram shows, however my overdrive light is still flashing, (cruise is fixed) stevie_b you seem to know whats going on, any other ideas? on why im still getting code 42 and the light still flashing, I even reset my ECU which fixed the issue until the drive after next. Not sure TBH. Does your car have a Digital Speed Converter or a Top Speed Delimiter fitted? These can sometimes give up and cause a code 42, because anything that was getting the speed signal from the DSC or TSD would now not be getting anything. If it's not an imported car, then that's almost certainly a "no". My car's got a manual gearbox so doesn't have the overdrive toys. I would follow the flow of the speed signal: check if the speedo still works. Then check if the odo still counts up the miles/kms as you drive. Does your power steering get heavier (as it should) when you go over about 50mph? It could be loose wires around the back of the speedo dial, or around the odo unit. It's possible that the odo unit has dry solder joints (the joints have been known to give up after 13 or so years of use). This can be hard to diagnose though. Link to comment Share on other sites More sharing options...
wisc Posted June 27, 2007 Share Posted June 27, 2007 Not sure TBH. Does your car have a Digital Speed Converter or a Top Speed Delimiter fitted? These can sometimes give up and cause a code 42, because anything that was getting the speed signal from the DSC or TSD would now not be getting anything. If it's not an imported car, then that's almost certainly a "no". My car's got a manual gearbox so doesn't have the overdrive toys. I would follow the flow of the speed signal: check if the speedo still works. Then check if the odo still counts up the miles/kms as you drive. Does your power steering get heavier (as it should) when you go over about 50mph? It could be loose wires around the back of the speedo dial, or around the odo unit. It's possible that the odo unit has dry solder joints (the joints have been known to give up after 13 or so years of use). This can be hard to diagnose though. not sure about the heavy... but the odo and speedo still work correctly I have the speed limiter removed by a SMT-6 piggyback chip. Link to comment Share on other sites More sharing options...
wisc Posted September 9, 2007 Share Posted September 9, 2007 Anyone know any more about this or found any more info on this? I'm still flashing... Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted September 9, 2007 Share Posted September 9, 2007 I still get this along with constant light/heavy steering. I'm off to try out Matt's fix. Will let you all know how i get on. Link to comment Share on other sites More sharing options...
