Jake Posted June 21, 2006 Share Posted June 21, 2006 Hey Ash Re your oil leak problem on .co.uk Check your Cam Pos Sensor's rubber gasket. If it's leaking the oil will run down between injectors #5 and #6 and then down onto the starter motor and then progress to whatever else below. I had the same problem on my white VVTi once. (I can't post on .co.uk 'cos my account was deleted for some reason) Link to comment Share on other sites More sharing options...
Suprash Posted June 23, 2006 Share Posted June 23, 2006 Thanks Jake, I didnt see this mate. Regarding your account, I advised them, lol Right would the cam position sensor be around here......shown in red sqaure box on pic below.....? Link to comment Share on other sites More sharing options...
Jake Posted June 23, 2006 Author Share Posted June 23, 2006 Right would the cam position sensor be around here......shown in red sqaure box on pic below.....?Yeah, around there. Easiest way to find it; it's bolted to the cylinder head directly between the two bolts that secure the rear engine hook to the head. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted June 23, 2006 Share Posted June 23, 2006 Hey Ash Re your oil leak problem on .co.uk Check your Cam Pos Sensor's rubber gasket. If it's leaking the oil will run down between injectors #5 and #6 and then down onto the starter motor and then progress to whatever else below. I had the same problem on my white VVTi once. (I can't post on .co.uk 'cos my account was deleted for some reason) Quick Ban him for posting a link to the other site!!! Link to comment Share on other sites More sharing options...
