Brian Jackett Posted November 5, 2001 Author Share Posted November 5, 2001 So just so I understand, you have designed an Air Fuel mixture gauge, to show the air fuel mixture running in the Supra. How much is this gauge regards Link to comment Share on other sites More sharing options...
Branners Posted November 5, 2001 Share Posted November 5, 2001 Quote: from Ring Master on 7:30 am on Nov. 3, 2001[br] Ash, Is detonation bad ? ROFL !!! Let me tell you a test id be keen to see. Perhaps Branners or Brian might take part, results would be interesting! Reset the ECU, go for a mild blast and take an ignition timing reading at the end. Then go for a mental blast running 1.4 , and test timing again. I'd be very keen to see just how far the ECU has retarded timing. Perhaps we could hook up the wide band lamda at the same time ? Ash, Branners , fancy a get together some time to do some real testing ? Beers on me.... Im happy to go for that, my car is probably on the very edge of blowing up so it should show just how close it is... JB Link to comment Share on other sites More sharing options...
THOR Racing Posted November 5, 2001 Share Posted November 5, 2001 >So just so I understand, you have designed an Air Fuel mixture gauge, to >show the air fuel mixture running in the Supra. Yes, running in any car as all O2 sensors are the same. 0->1V outputs >How much is this gauge Retail will be £100. Remember it shows injector duty cycle as well. Plus it will have a dial to select the type of display you want, bar, dot etc etc. It looks crap now but the final thing will look the ticket :-) I'm also doing an LCD one for those who like numbers rather than lights. This will be about £150 I guess. There are other units out there so if you're in a hurry do a search on the web for AFR meters. Regards Pete Link to comment Share on other sites More sharing options...
Brian Jackett Posted November 5, 2001 Author Share Posted November 5, 2001 When will the LCD £150 be ready, and is this the complete kit to connect up to the Supra. Can it be left connected all the time regards Link to comment Share on other sites More sharing options...
mark brown Posted November 5, 2001 Share Posted November 5, 2001 Pete For a wideband Lambda sensor, try Regal Autosport on 02380 791000 ask for Chris, that where I got my wide band sensor from. Mark Link to comment Share on other sites More sharing options...
