b_have Posted June 19, 2006 Share Posted June 19, 2006 Trying to wire in an LED warning light to indicate when the pump is running. Anyone know how to do this (I am a leccy numpty) Seems the pump is constantly live and relays to earth, or something like that Quote Link to comment Share on other sites More sharing options...
TRD3000GT Posted June 19, 2006 Share Posted June 19, 2006 Trying to wire in an LED warning light to indicate when the pump is running. Anyone know how to do this (I am a leccy numpty) Seems the pump is constantly live and relays to earth' date=' or something like that [/quote'] Pick up one of the 12V led's from maplin and run a wire to the positve and negative terminals of the pump this will put the LED in a parallel circut and when the pump is turned of the LED should light up. p.s. the LED has to be fitted the right way round.. the long leg is the + http://www.maplin.co.uk/Module.aspx?ModuleNo=35782&criteria=led%2012v&doy=16m6 Quote Link to comment Share on other sites More sharing options...
Lucifer Posted June 19, 2006 Share Posted June 19, 2006 Or get the Display from Aquamist Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 19, 2006 Share Posted June 19, 2006 That will only tell you that the pump has power to it... Not that it is working! Quote Link to comment Share on other sites More sharing options...
Lucifer Posted June 19, 2006 Share Posted June 19, 2006 That will only tell you that the pump has power to it... Not that it is working! I was under the impression that it was a flow display not a power display. Ive been using it for a couple of years now. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 19, 2006 Share Posted June 19, 2006 Or get the Display from Aquamist Good advice;) as you have no way of telling if you have any problems, ie blocked jet, no water etc, so if your using the water injection as intended to enable you to lean out AFR a bit and advance the timing, you are asking for trouble. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 19, 2006 Share Posted June 19, 2006 I was under the impression that it was a flow display not a power display. Ive been using it for a couple of years now. DDS2 and DDS3 will both tell you about problems and flow if configured right. Quote Link to comment Share on other sites More sharing options...
TRD3000GT Posted June 19, 2006 Share Posted June 19, 2006 That will only tell you that the pump has power to it... Not that it is working! As far as Im aware the pump does not see any voltage untill its automatically turned on by the solenoid.. If it does then of course this would not work. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 19, 2006 Share Posted June 19, 2006 I was under the impression that it was a flow display not a power display. Ive been using it for a couple of years now. Oops! - Sorry, you hadn't posted when I typed that. I was talking about the LED connected to the power lines. A flow display is what you want. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted June 19, 2006 Share Posted June 19, 2006 Yes thats right Matt it would only indicate current to the pump. The flow meter is the way to go Charlie. Quote Link to comment Share on other sites More sharing options...
heckler Posted June 19, 2006 Share Posted June 19, 2006 Trying to wire in an LED warning light to indicate when the pump is running. Anyone know how to do this (I am a leccy numpty) Seems the pump is constantly live and relays to earth' date=' or something like that [/quote'] If you go to the aquamist website - theres a "how to" on there Quote Link to comment Share on other sites More sharing options...
b_have Posted June 19, 2006 Author Share Posted June 19, 2006 Thanks guys. Quote Link to comment Share on other sites More sharing options...
dandan Posted June 19, 2006 Share Posted June 19, 2006 Charlie, If you look into it and get a price for the erl warning light system, would you let me know the price as I may get one as ell. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted June 19, 2006 Share Posted June 19, 2006 LOL Group buy anyone! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted June 19, 2006 Share Posted June 19, 2006 Just in case anyone is interested, i have a DDS2 if anyone needs one. Quote Link to comment Share on other sites More sharing options...
Supra ST Myster Posted June 19, 2006 Share Posted June 19, 2006 i have connected mine off the relay that switches on the pump, so when the pump is running the light comes on, very easy to do. Just connect one side to +12V and then the other side of the LED to the N/O of the relay, proving its 0V that is switching for the pump to work, Make sure the LED has a resistor in series. Quote Link to comment Share on other sites More sharing options...
Wez Posted June 20, 2006 Share Posted June 20, 2006 LOL Group buy anyone! Wahoo, sort us out a price then How much are they normally? Quote Link to comment Share on other sites More sharing options...
