Delimiting ......still!!
matt
Finally found the divider used to convert my car. It was up on top of the gearbox !!!
Basically the 3 wires from the box are cut and this thing is wired in ....
3 in 3 out
Anyway I put the wiring back to stock and the car drived faultlessly ..... in fact its a huge improvement!!
Very odd to see the speedo over 180!!!
I'd like to re-use the divider to simply convert the speedo and odo.
But.... apart from the speed signal wire from the box (blue/silver?)
what do the other 2 do ??
Are they simply +ve/-ve ??
I assume the divider requires power??
Anyone with a wiring diagram??
Hey Pete
No .... it only has 3 wires in and 3 out
It was originally connected to all 3 wires from the rearmost sensor on the autobox.......
Plastic unit
I've already checked out your site ....... but feel I'm pissing in the wind with the original signal divider , so would like one of yours
I'm based in High Wycombe , I seem to recall you are not too far away(Maidenhead?)
Maybe I can give you a ring??
