dandan Posted June 18, 2006 Share Posted June 18, 2006 Guys, I'm trying to install my EMU software and keep getting this error after the install completes. It pops up in a seperate window and says the installation did not complete. I've googled the error and found it's to do with the Installer. I've deleted my temp docs in c\temp and windows\temp. msiexec seemed to always be running so stopped that as well before trying again. Anyone got any ideas? This is an XP pro OS. All input appreciated. Cheers Dan Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted June 18, 2006 Share Posted June 18, 2006 have you tried updating windows installer? i think THIS is what you need Quote Link to comment Share on other sites More sharing options...
dandan Posted June 19, 2006 Author Share Posted June 19, 2006 I'll take a look when I get home, thanks. Although, thinking about it - I did read that the XP installer is the latest type. Is that right? Quote Link to comment Share on other sites More sharing options...
edd_t Posted June 19, 2006 Share Posted June 19, 2006 the update the installer now and again. so if yours is still the version that came installed with XP it will be old. i think there onto version 3.1 now... Installer 3.1 v2 Quote Link to comment Share on other sites More sharing options...
dandan Posted June 19, 2006 Author Share Posted June 19, 2006 Thanks guys, I tried updating the installer (in fact I did update it) but still get the same error. Any ideas? Quote Link to comment Share on other sites More sharing options...
dandan Posted June 19, 2006 Author Share Posted June 19, 2006 Any more pointers fellas? Quote Link to comment Share on other sites More sharing options...
michael Posted June 20, 2006 Share Posted June 20, 2006 Could be a dodgy package, does it just run through from start to finish or are you prompted to enter options along the way? You could try launching the install with logging enabled... msiexec /i /Lime c:\logfile.txt Don't kill the msiexec unless it's been sat there for ages doing nothing, it's the thing that's in charge of installing this for you Are you installing from a CD? It might be worth hunting around on it for an alternative setup.exe (or similar) - the one that has been packaged up could be looking for something that isn't there or relying on a particular set of files being present on your PC and falling over if they aren't there. With a manual install or logging enabled this should be revealed more clearly. Failing that ring Rod Hull. Quote Link to comment Share on other sites More sharing options...
dandan Posted June 20, 2006 Author Share Posted June 20, 2006 Thanks Michael, I've tried installing from the cd and the zip file from Mohd's website, only one setup file I think but will check again. Install runs fine start to finish, entering serial no of unit and name, company etc. Only at very end does this little seperate window pop up identifying the error occured. I will try the logging option this evening - do Ijust enter than string of text in start-run ? How do I stop the logging after I try the install and what do I look for in the log? Quote Link to comment Share on other sites More sharing options...
michael Posted June 20, 2006 Share Posted June 20, 2006 That string, with the path to the setup, should sort you out with logging, I'm not sure what we are looking for in the logs to be honest but it might give us more idea about the underlying issue. If we can access the download perhaps a few could test it? Quote Link to comment Share on other sites More sharing options...
dandan Posted July 7, 2006 Author Share Posted July 7, 2006 Thanks Michael, I've been on hols for a week but I'll try this over the weekend and let you know. Quote Link to comment Share on other sites More sharing options...
