Dave F Posted June 17, 2006 Share Posted June 17, 2006 In the wet weather, that this country is so good for, my seatbelt becomes slightly damp. I have just removed all of the trim from the boot forward and poured water firstly over the bottom part of the glass and then the top. The leak seems to be at the top above the glass right in the middle, my question is how do I sort this? I assume I can use silicone gel and if so which one, any help appreciated. Cheers Dave Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 17, 2006 Share Posted June 17, 2006 Try gettimg some sealant in there first Dave. The rear windows are bonded and bolted in, so it's not an easy task to remove the whole window to re-seal it. Quote Link to comment Share on other sites More sharing options...
Dave F Posted June 18, 2006 Author Share Posted June 18, 2006 Going to try that today fella, is ordinary household sealant ok for this (the exterior stuff) Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 18, 2006 Share Posted June 18, 2006 I'd guess that would be OK. The actual stuff they use is more like Sikaflex. Quote Link to comment Share on other sites More sharing options...
