Andyhannah Posted June 17, 2006 Share Posted June 17, 2006 right ive searched threads but my symptoms are differnt i think. you can put overdrive off and it stays off but if you have it on it just flashes off and on all the time.and it annoys the hell outta me. any ideas guys. its not been delimited so it isnt that. andy Link to comment Share on other sites More sharing options...
Jake Posted June 17, 2006 Share Posted June 17, 2006 Check for bad connection, earth especially, on the speedo converter or into the back of the Odometer. Link to comment Share on other sites More sharing options...
jamesmark Posted June 17, 2006 Share Posted June 17, 2006 have you checked you error codes? dunno how to do it but do a search as i had this but my slip cont light also flashed See here for error codes for the auto box Link to comment Share on other sites More sharing options...
Andyhannah Posted June 17, 2006 Author Share Posted June 17, 2006 i havent got a speedo converter Link to comment Share on other sites More sharing options...
Jake Posted June 17, 2006 Share Posted June 17, 2006 What have you got then, a 110mph speedo? Link to comment Share on other sites More sharing options...
Andyhannah Posted June 17, 2006 Author Share Posted June 17, 2006 180 km/h speedo Link to comment Share on other sites More sharing options...
Dave Posted June 17, 2006 Share Posted June 17, 2006 check out this thread on how 2 read codes and the mil light is the engine shaped light in the top right hand display this is the one that flashes the code and dont worry m8 your not alone 90% of us have had this prob http://www.mkivsupra.net/vbb/showthread.php?t=35920 Link to comment Share on other sites More sharing options...
Max Headroom Posted June 17, 2006 Share Posted June 17, 2006 I have it too and I dont have a delimiter also Link to comment Share on other sites More sharing options...
alan_blue Posted November 5, 2006 Share Posted November 5, 2006 so what is the general thing to do for this problem then ? Link to comment Share on other sites More sharing options...
Omlaysause Posted November 6, 2006 Share Posted November 6, 2006 I took my dash panels off yesterday to fit a new CD player. Because the ISO adaptor wasn't correct I couldn't fit everything back, so ran about with them all off and guess what started flashing on and off! So I'm guessing it's to do with one of the connections being broken. When I put them back on I'll do it a panel at a time until it stops(hopefully!) and let you know which connector it is. Link to comment Share on other sites More sharing options...
Ian W Posted November 6, 2006 Share Posted November 6, 2006 I took my dash panels off yesterday to fit a new CD player. Because the ISO adaptor wasn't correct I couldn't fit everything back, so ran about with them all off and guess what started flashing on and off! So I'm guessing it's to do with one of the connections being broken. When I put them back on I'll do it a panel at a time until it stops(hopefully!) and let you know which connector it is. yours is to do with the dash being unplugged and turning the ignition on mate. haven't read the whole thread thoroughly so can't comment on the rest. Link to comment Share on other sites More sharing options...
Ian R Posted November 6, 2006 Share Posted November 6, 2006 Is the traction control light flashing in unison with it ??? Link to comment Share on other sites More sharing options...
Robbie Posted November 6, 2006 Share Posted November 6, 2006 From memory to get the O/d light to stop flashing the quick way, remove the main ecu solonoid/fuse from the engine bay fusebox. I think its the 2nd up onthe right. This will rset the main ecu. So you 'll have to go out and run the car for its ecu t0 re-learn The other thing to check is the trac fuse. its a 7.5 amp 4th up on the right Link to comment Share on other sites More sharing options...
alan_blue Posted November 6, 2006 Share Posted November 6, 2006 if the trac control fuse is removed or broken will it cause th elight to flash? Link to comment Share on other sites More sharing options...
wwe Posted November 6, 2006 Share Posted November 6, 2006 hi mate i had the same probs and took mine to rip off kings (toyota maindealer) but they may have chagered me a mint but they found it it was a little sealed box behind the dash . the part should cost about £40+ vat and if u let toyota do it they will charge £116+vat to fit it so if u know how to take ur dash apart i would do it my self Link to comment Share on other sites More sharing options...
alan_blue Posted November 6, 2006 Share Posted November 6, 2006 what box was it mate? Link to comment Share on other sites More sharing options...
wwe Posted November 7, 2006 Share Posted November 7, 2006 on my visual safety report it says em lamp display unit i hope this has help you Link to comment Share on other sites More sharing options...
