DamanC Posted May 12, 2008 Share Posted May 12, 2008 Need to get mine sorted soon. Link to comment Share on other sites More sharing options...
twijesiri Posted May 12, 2008 Share Posted May 12, 2008 realy good thread this as i was going to get the gas from Halfords. Now i think i will just cough up and do the job properly. Link to comment Share on other sites More sharing options...
Guest banherc Posted May 13, 2008 Share Posted May 13, 2008 The only problem with that is, the fuel consumption goes down even more when the AC is used all the time! Very true, but just run the air con more often then, it will stop the compressor oil seal becoming to dry and therefore leaking gas, which in the long run could ruin the compressor (big bucks then). Link to comment Share on other sites More sharing options...
SimonB Posted May 13, 2008 Share Posted May 13, 2008 It has virtually no effect on the fuel consumption. And certainly far less than the drag from having the window open. Link to comment Share on other sites More sharing options...
razza Posted May 13, 2008 Share Posted May 13, 2008 fule consumptions rubbish anyway, so i doubt the aircon being on is going to make a noticeable difference. It doesn't have to be used akll the time, a good run every month should work I think, mine just sat around for 3 months so was no good Link to comment Share on other sites More sharing options...
