Greystoke Posted June 16, 2006 Share Posted June 16, 2006 Should I be seeing oil on the front of the HKS SSQV Blow Off Valve. Link to comment Share on other sites More sharing options...
Ark Posted June 16, 2006 Share Posted June 16, 2006 It's just blow-by oil from the turbos - nothing to worry about in small quantities. If it's spraying out like a hose _then_ start worrying. Link to comment Share on other sites More sharing options...
Greystoke Posted June 16, 2006 Author Share Posted June 16, 2006 It seems to be only a small bit that is there. Thats ok then. Thanks. Link to comment Share on other sites More sharing options...
theyoungeone Posted June 16, 2006 Share Posted June 16, 2006 if im talking out my arse please tell me. I have the same problem mate, when i was last at turbofit in mk (nice guys) they told me it was proberly a oil breather pipe that was blocked, its the one in-between the intake manifold and passenger side rockercover. it has a ballberring valve inside that is ment to shut when the engine comes on + boost, but when they get clogged up with crap they dont shut all the way and blow oil throught the breather system and in to the pipe work then in to the engine. and when you use your BOV as such it squirts a bit out. Link to comment Share on other sites More sharing options...
Ben-san Posted June 16, 2006 Share Posted June 16, 2006 As Ark said, there's a complimentary amount that normally blows through. You might notice that a stock BOV is usually a little caked with the stuff. If it's a lot, then don't ignore it. And as the young one says, a catch tank will sort this if you're worried about drips. Link to comment Share on other sites More sharing options...
Greystoke Posted June 16, 2006 Author Share Posted June 16, 2006 I have the same problem mate, when i was last at turbofit in mk (nice guys) they told me it was proberly a oil breather pipe that was blocked, its the one in-between the intake manifold and passenger side rockercover. Does anyone have a pic of where this pipe is. Link to comment Share on other sites More sharing options...
Ben-san Posted June 16, 2006 Share Posted June 16, 2006 This is the breather pipe in question. Link to comment Share on other sites More sharing options...
Greystoke Posted June 17, 2006 Author Share Posted June 17, 2006 Thank you. Link to comment Share on other sites More sharing options...
Jspec Germany Posted June 17, 2006 Share Posted June 17, 2006 anybody have links to pics of a catch tank install? Link to comment Share on other sites More sharing options...
