The FSE - Adjustable Fuel Pressure Regulator - How / What / Where
Dragonball
Originally posted by dude
Some say yes some say no but Pete Betts at THOR is gonna do a step by step Dyno 'experiment ' using his car with and without the FSE , there will be no arguing with the results and THEN would be the time to make up your mind , personally i have one and love it my car made 380 at the hubs and 404 ft lb on Petes dyno with good fueling so i will be leaving mine on !!!!
Dude:flame Dev
Results are in m8
Musssssst resisssssst....
(do not say 'told you so' - I resisted!):p
  • Replies 55
Would like to see these results :thumbs:
The power boost valve when added to a car and not setup properly is just going to add more fuel and in theory reduce the power output due to the car running too rich, safe but rich, i don`t believe there is any need to run richer than Toyota intended.
I have one on mine and with the PBV turned up a sensible amount I was able to pull loads of duty out of my injectors in the fuel map of my AEM, i tune my car using a wideband and det cans and the engine is clean as whistle without running rich and it pulls like a train as well, much more responsive.
Just my 2c
:thumbs:
Just my 2c
:thumbs:
WEZ anything added to a car and not set up properley is going to F**k it up !!!!! Thats what its all about getting it fitted and set up correctly , if you just 'chuck' something like that on your asking for trouble !!!!:confused:
Dude:flame Dev
Dude:flame Dev
Couldn`t agree with you more dude :thumbs:
Alot of people who fit these themselves are prob just wacking em on without setting up properly assuming that it has made an improvement when in some cases it could make it worse.
I know frightening isnt it !!!
Dude:flame Dev
