Decat > 1st Cat Temp Probe
Angarak
When decatting, I've read that people tie the obsolete 1st cat temp sensor up out of the way.
Is it safe to unplug it so I can remove it completely (ie: no ill effects)?
I would have thought so, but Im curious to know if others have unplugged it (the plug is alongside the transmission tunnel in the drivers footwell.
Cheers
i think with the amount of people that just say tie it up rather than remove, there must be a reason for that. But then i'm not technical with cars, so i probably shouldnt be posting in here, so i'm gona end this now and plod along into another section
good bye :)
Cheers Guys,
It causes a fault code. It might be possible to stick a resistor in the plug pins instead but why bother, just tuck it out the way...
-Ian
Should I be bothered about it causing a fault code?...will that effect the running of the car in anyway?...should I get a 'warning' light somewhere on my dash to indicate this?
I'd like to remove it so I can use that particular hole on the transmission tunnel to wire my AEM UEGO Sensor into my 2nd decat.
Cheers
  • 3 years later...
