Gasping for air!
Guru
I really need some advice on this. My clock, heater and blower controls are still dead! I have checked fuses in the engine and cabin locations. The radio fuse did blow but I cannot find another dead one.
Can anyone suggest which fuse to check or what the problem could be other than this?
No I didn't do anything I think that should have caused the problem Ben :(
I will check the fuse for the lighter tomorrow Animal and the rest of the panel come to think of it. It's just sods law that the weather is soooooo hot when I have no air or AC.....
My heater stopped working when I inadvertently (SP) disconnected a connection in the passenger footwell. It was only a three wired connector but it fecked me up for a few days figuring it all out.
Other than that, I'd check out all the fuses in the engine bay and in the drivers footwell just to be sure.
I had similar fault after fitting a new stereo a couple years back and indeed was cigar lighter fuse in drivers footwell fuse panel!
Had me confused as to the relationship between lighter, heater controls blower and clock but it was the culprit.
Think may have shorted out the cigar lighter semi-exposed terminals on stereo cage when refitting facia panel.
Was a sweltering hot day to loose A/C controls on too!
  • 7 months later...
Yes mate i did , i found out my heater control box(yellow box) which sits on the stereo cage was missing , i have installed this but still no heater , make things worse no clock either .:( . There is still one more plug sitting behinde the dash is there another box missing?
