19 inch & Judder
dil
A 6-speed NA does not exist. unless someone has the money to pay for the conversion - which would be pointless as you could upgrade to and insure a TT with the money it would cost to do it.
The 6-Speed TT uses a Getrag box because Getrag are world renowned for their gearboxes.
The TT manual will handle 800ish HP if applied correctly with a clutch that can take it.
The 5-Speed NA gearbox is probably the same unit used on the GT-4 celica. My mate had a GT-4 celica and it was always a b1tch in 1st and 2nd but then again in the end his 4th gear syncromesh welded itself to something else inside it. :)
...Anyway this is nw way off topic a new thread should be started if you wish to discuss gearboxes as this thread was about judder from wheels...
Im pretty sure the 6speed NA does exist, they had 5 speeds to start with, then a few had 6 speeds and then I think they went back to 5 speeds.
I think Ibrars mate had a 6 speed NA which was a rebuild after a rather interesting excursion off the road by a different UK Supras member. The car went through a fence with associated fence post embedded in the rear screen.
JB
Quote: from Alex Holdroyd on 3:10 pm on Nov. 6, 2001[br]
... USE THE CORRECT TOYOTA V-160 OIL...DO NOT USE ANY SUBSTITUE OIL.
... gearbox oil is about £25 per litre ...
Alex,
I tried to get some Toyota V160 oil myself but it is very hard to get hold of. A fellow MKIV owner suggested using the Esso ATF Dexron D-21065 oil, which is much easier to get and a whole lot cheaper. This Esso oil is also mentioned in the Supra manual and is approved by Toyota for use in the Getrag gearbox.
Flavio
http://www.mkivsupras.co.uk/
(Edited by Flavio at 9:28 pm on Nov. 6, 2001)
6 speed N/A's are rare as poo!! and it took me ages to find mine, sixth gear gives a nice cruising rpm on the motorway , and even my n/a although not as brutal and some days i do wish it was an TT has a enough torque to keep it trundling around town in 6th aswell, cant say though whether having a 6th gear improves fuel economy, i only get about 200 miles a tank with 75:25 town:motorway driving
Alex,
Flavio
Why doesn't any one keep me appraised of this changes in policy....;)
6-speed NA's, dextron oil for gearboxes....how much more of my knowledge that I've built for the last year is bollox....
I'm gunna have to fire my researcher.....
