Terminator Posted June 14, 2006 Share Posted June 14, 2006 Just to clarify, I had my system checked every year and it did not need refilling. I use AC every time the car is used, which shows the benefits of regular use. It has only been during a period of insufficient use of the system that the pressure dropped enough to need a charge. A simple check anyone can do is run the car for a few minutes with aircon set to max. Raise the revs to 2000 wait 30 seconds, the sight glass, next to the H cap, should be perfectly clear. Any bubbles or milkyness visible after this time means the gas is low, but probably not low enough to trigger a fault code. Bubbles etc at lower rpm and just after AC activation is normal. Link to comment Share on other sites More sharing options...
monkey76364 Posted June 14, 2006 Share Posted June 14, 2006 Raise the revs to 2000 wait 30 seconds, the sight glass, next to the H cap, should be perfectly clear. Any bubbles or milkyness visible after this time means the gas is low, QUOTE] Where is this located I hae no idea lol Link to comment Share on other sites More sharing options...
Ian W Posted June 14, 2006 Share Posted June 14, 2006 Raise the revs to 2000 wait 30 seconds, the sight glass, next to the H cap, should be perfectly clear. Any bubbles or milkyness visible after this time means the gas is low, QUOTE] Where is this located I hae no idea lol i think it's under the bonnet just behind/in front of the radiator, someone will clarify though i'm sure. Link to comment Share on other sites More sharing options...
