Speedo slow to respond.
RedM
Plant your foot and see what happens :D
Ha ha, I normally do. It's only because i'm pootling around for a couple of weeks that I have time to notice this stuff. It could have been like this forever and I have no idea.
Can we have auto supra owners have a look at this next time they are driving?
Does your speedo rise as soon as you start moving? Even at crawl? Does it lag behind for a few mph?
Would like to know.
JDM TT auto here, I dont have a problem works as it should, except always reads high above 30.
Possibly a dirty connection behind the speedo, some switch cleaner on the plug may help.
May be a speed signal sender fault, as a few of you have the same fault it is more likely to be a worn component.
If it is the sender it can only get worse.
If it helps I had an issue with the speedo jumping all over the place. Turned out to be bad solders where the speed converter had been added.
Take out the dash fascia and try giving them a re-solder, sorted mine out a treat! Took about half an our tops!
NB when taking out the dash read some of the notes on doing so as you can end up activating the airbag light so it stays on and you then have to re-set it. I did this no big problem but better avoided if you can.
  • 2 years later...
Same problem here, crawling in traffic mine reads 0 till i reach 5mph then it shoots up to 5mph and works fine and same when stopping i slowly stop and the speedo slowly goes down to 5mph then seems to get jammed there until i fully stop then it suddenly shoots down to 0 like the engine has cut out, and my revs are only around 500rpm :(
