GetawayDriver Posted June 9, 2006 Share Posted June 9, 2006 Hello, Car has been doing this for a while so i've just been driving about with the boost controller off. If i switch it on it still hits fuel cut. i am running some very reasonable boost settings on my Blitz SBC-iD III and powermeter. i've tried adjusting the pots on the pete betts FCD i have but to no avail - i still hit fuel cut randomly in 4th, 5th and 6-th. sometimes it will boost to 1.2 bar no worries, other times it hits fuel cut at an indicated 0.9 bar. could it be a boost spike that is too quick for the boost controller to pickup, but the ecu can? could something else cause this? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 9, 2006 Share Posted June 9, 2006 Are you 100% sure its fuel cut? Does your ECU light flash up? Link to comment Share on other sites More sharing options...
cashpoint Posted June 9, 2006 Share Posted June 9, 2006 Could be a loose connection. I remember being a Leon's when Branners was they with a similar problem turned out to be a loose connection. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted June 9, 2006 Share Posted June 9, 2006 We had a TRL converter go down on us a few months ago, could be a dodgy one, you never know Link to comment Share on other sites More sharing options...
GetawayDriver Posted June 9, 2006 Author Share Posted June 9, 2006 yeah, def fuel cut - almost always close to the red line. if it did it consistently i'd be able to pin it down, but it's so random i can't think would it could be but a loose conntection or a faulty unit. my SMIC is shagged, i can actually see though it - could that contribute to it? i have a new FMIC to fit, just waiting on the pipe kit. Link to comment Share on other sites More sharing options...
Sharpie Posted June 9, 2006 Share Posted June 9, 2006 Just for reference: http://www.thor-racing.co.uk/files/Setting_up_the_VFCC.doc http://www.thor-racing.co.uk/files/VFCC_SUPRA_Install.doc Link to comment Share on other sites More sharing options...
GetawayDriver Posted June 9, 2006 Author Share Posted June 9, 2006 thanks pete. i will check all the connections etc and re-setup with those instructions. Link to comment Share on other sites More sharing options...
